Glare Free light operation
Firn
Firn
23 Pro ER
I agree with you @Firn and @Cvh8601 , the glare free light are not necessarily a "set it and forget" thing. The driver still needs to give input to operate appropriately, especially in urban areas or when navigating through lots of intersections.
The biggest payoff for me is where I live, mostly rural and light suburban. Glare free really is a game changer in these conditions on lighter traveled single lane roads and highways. For me it's much more enjoyable and better lighting than the constant high/low switching of the old "automatic" setting.
@Firn , for me, the "push the stalk forward" cycles through the lights in this order: glare-free > low only > high only > back to glare-free. If I pull the stalk back while in glare-free, I get high beam only, and back to glare-free when I release. I don't know if this is in the 2024 or Pro trim or if I just got lucky, but it's consistent and easy to manipulate.
I feel like enabling it and disabling it was different when I first enabled the feature in forscan, more like you describe. I actually prefer the way it is now, I can turn it on or off, and i can flash. The issue is simply that the same action does not always do the same thing, and you cannot really tell when it's going to do which.
digitaldad
ABQ
'23 Lariat ER MaxTow
@B177y & @Firn, these last two posts are helping me...as I just activated this feature but didnt see anything working while driving (there wasnt much time where cars weren't around though and I was brighting everyone trying to get it to work, so I stopped).
Besides the stalk pushing/pulling as mentioned, my question is: do I have to have the auto lights selected on the rotator circle or will this function when simply on?
B177y
Bill
Olympic Peninsula, WA
... do I have to have the auto lights selected on the rotator circle or will this function when simply on?
Yes, glare free only works when the switch is in the "Auto" position. The headlight symbol on the instrument screen will be green with an "A" inside of it.
digitaldad
ABQ
Thanks, I thought I recall seeing two green icons next to each other. Will be awhile before I can test again, have an upcoming road trip in another car.
B177y
Bill
The two green headlights symbol indicate that the parking lights are on via the switch, not glare free lights. Glare free looks like a single headlight symbol, similar to the blue high beam symbol but green with an "A" inside of it.
Page 113 in the US manual. There's nothing about glare free because we're in the US, but here's the symbols. Glare free looks like the "autolamps" symbol in green instead of the default white (auto high/low only).
Ford F-150 Lightning Glare Free light operation 1000006623
From Canada, here is Owners Manual information for Glare Free (I have added notes and pics):
GLARE FREE LIGHTING REQUIREMENTS
The system turns on if all of the following occur:
  • You switch the system on (Settings : Vehicle : Lighting : Glare free)
    Ford F-150 Lightning Glare Free light operation 1740158808335-zk
  • You set the lighting control to the autolamps position (C).
    Ford F-150 Lightning Glare Free light operation 1739297522402-aj
  • The ambient light level is low enough.
  • Your vehicle speed is greater than approximately 52 km/h (32 mph). [Note: in the U.S., folks are reporting a lower engagement speed, e.g. 25 mph.]
The system adapts the lighting to avoid glare if all of the following occur:
  • You switch the system on.
  • You set the lighting control to the autolamps position.
  • The system detects an approaching vehicle's headlamps or rear lamps.
The system turns off if any of the following occur:
  • You switch the system off.
  • You set the lighting control to any position except autolamps.
  • The ambient light level is high enough.
  • The system detects severe rain, snow or fog.
  • The system detects street lighting.
  • The camera has reduced visibility.
  • The vehicle speed falls below approximately 30 km/h (19 mph).
Note: The deactivation speed is lower on curves.
GLARE FREE LIGHTING INDICATORS
Ford F-150 Lightning Glare Free light operation 1739296962740-ei
Illuminates Green to confirm when the system is ready to assist. If your icon is white that is Auto High Beam, not Glare-free.
OVERRIDING GLARE FREE LIGHTING
Push the lever away from you to switch the high beams on.
Ford F-150 Lightning Glare Free light operation 1739297265273-ml
Push the lever away from you again to switch the high beams off (this will just be low beams).
Ford F-150 Lightning Glare Free light operation 1739297291060-0
Push the lever away from you for a third time to switch glare free lighting back on.
Ford F-150 Lightning Glare Free light operation 1739297339498-73
Note: Auto High Beam (white A) will light the blue head light icon when operating in auto high-beam mode. Glare-free (green A) does not do this.
digitaldad
ABQ
Thanks for those notes, pretty sure I saw this on-screen but may have quickly pushed the stalk...which prob messed it up.
Edit: yep, saw it tonight although it wasnt dark enough to emit brights, these were the symbols.
Ford F-150 Lightning Glare Free light operation 1739299017931-c3
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
Well, I don't have the "Glare-free" on/off button on the Lighting screen for starters. I do get the all green glare free symbol.
The system worked as expected last two nights, you can see the typical left side high beam disappear, with some of the center lenses twitching on & off. GF also seems to react quicker on & off than the other auto high beam system, which sometimes would take 3-5 seconds to return.
I also get no response and never see the blue high beam symbol if I push the stalk forward with GF engaged. I can get the GF system to cycle on and off with repeated stalk pushes. I'll have to try the standard high beam setting.
LHoffmanjr22
Larry
2024 Ford F150 Lightning Flash
Does anyone know if this is something that will become an option for owners outside of Forscan? I am assuming it's only disabled in US trucks because of government regulation around Glare Free. If the new Model Y has it, has the law changed to allow this to be used on American roads?
I know, I know. Expecting Ford to send new or improved features out via over the air updates is sketchy as best, but we can still hope, can't we?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Lightnings follow the standard that is used in the EU and Canada. The US came up with a separate standard and the Lightning hardware can’t meet the US standard. The model Y was designed to the US standard.
Runaway Tractor
Yes
Locking the high beams on (Blue indicator) is only possible when stopped. You can cycle low > GF > High by pushing the stalk forward only when stopped. When you're moving more than 7mph, pushing the stalk only cycles Low > GF.
No there is no way to cycle it into locked high beam (blue) once you are moving.
NeuroDawg
Puget Sound, WA
'24 Flash ER (previously '23 XLT ER)
From Canada, here is Owners Manual information for Glare Free (with my added notes and instrument panel pics)
    Ford F-150 Lightning Glare Free light operation {filename}
etc...
What's the proper behavior when I turn glare-free off in the vehicle settings? Should it go to auto high-beams (without glare-free)? Or disable auto completely, and put the truck in manual mode? On my '24 Flash I've enabled glare-free and they work perfectly. When I turn off the setting, the auto high beam icon goes away on my dash and I must operate high beams manually. I would have thought I'd see a white icon and I'd have auto high beams, without the glare-free.
Firn
Firn
23 Pro ER
Glare Free IS the "Auto" now.
