Features compare list for 2024 Platinum & Lariat
https://www.ford.com/trucks/f150/f1...intcmp=vhp-cta-compare&models=platinum|lariat
I've theorized that Max Tow is the reason the Platinum's EPA range is 300 instead of 320 for all other trims. Max Tow is standard on a Platinum and optional on other trims. I've not verified this in any scientific way.
I believe it's the larger wheels, not Max Tow.Also the larger wheels.
I believed that too which is why I bought a set of Lariat take-offs. I wasn't able to detect an efficiency difference with different wheels.I believe it's the larger wheels, not Max Tow.
Obviously.....I believe it's the larger wheels, not Max Tow.
Yes, that brief peak load was the OBC topping up your HVB.Unless someone has a technical diagram, I am going to use my preconditioning to see how much electricity I use I have it set to high temp
55* out side coldish battery
Truck set for 740 departure
7:21 peak 11.5 kw
7:22 drops to 2 kw
7:23 to 7:40 leave less than 1KW
don’t see like a PTC heater is kicking on I know it jumped to 11.5 because the truck was at 89%.
@TaxmanHogYes, that brief peak load was the OBC topping up your HVB.
Like to see the "by the minute" snap shots a couple minutes after the battery returned to 90% SOC goal, I bet it's a lot less than the PTC values of around 5-6 KW
7:21 peak 11.5 kw
7:22 drops to 2 kw
https://shop.emporiaenergy.com/collections/energy-monitorsK, as a data nerd, what are you using to generate these? Is this from an aftermarket thing or is it in the ford app (which I obviously don't have yet since I don't have a truck yet)?
Yes I agree the mass is negligible. I've even seen some you tube tests of having 1500lbs or something in the bed, with minimal aerodynamic changes, and the efficiency barely moved. Like under 10% worse.Ignoring the lies most dealers will tell to sell a vehicle... Do the math.
The extra weight is negligible. Less than 1% weight difference from the added components, which translates to less than 1% range difference. Weight matters for acceleration energy cost, and we do more acceleration than most people believe (for example, changing direction on a wide curve highway is an acceleration even when done at a constant speed). But because F=ma is linear with mass, you'll see less than 1% change in energy cost due to the extra weight.
The extra cooling, when on, will draw about 5 kW. That can add up if you're hauling a long distance. Say you're towing for an hour in Death Valley in the summer...you'll need that cooler on and you'll use ~5kWh. Out of 130 kWh of battery on the ER, that extra use is about 3.8%, or about 6 miles out of ~150 miles range while towing.
Total range decrease due to having and using max tow is less than about 4% while towing in a hot environment. But it preserves long-term battery life.
You can gain that range back by slowing down a few mph. Once drag becomes dominant, the total energy cost to move the vehicle is proportional to speed cubed (aerodynamic drag introduces another multiple of velocity that's not accounted for in E=1/2m*v^2).
