MAX TRAILER TOW PACKAGE if not planning to tow?
shutterbug
Joseph
Phoenix
If you're planning to own the Lightning for a long time ie. 10 years, I'd say you would be better without the max tow option, with the truck being that old a decade from now, is likely not going to be a target of interest for someone wanting the option.
Save a few bucks and do without it
If you're going to flip it in 1-3 years, then that option would be more useful to subsequent buyers
OTOH, if you're keeping the truck for 10 years, Max Tow will cost less than $10 a month. I got it since I live in hotter than hell AZ with more than a few hills, so I thought it would help.
OP is in Eastern VA between DC & Richmond, sure it gets warm there too, but not hellish warm as AZ, different strokes for different folks, no right or wrong.
gratney
Terry
King George, Virginia
2023 F-150 Lightning Lariat ER / Azure Gray
Lab manager
It hits the 100's here during the summer...probably not as hot as AZ, but more humid. Considering the price difference, I think this debate has talked me into the package..although I know there's no definitive "right answer". But lots of the discussion has swayed me that way. I just can't wait to get the truck now. Casting a net out to several dealters for the best value.
shutterbug
Joseph
Phoenix
It's those days when the temperature doesn't go below 100 here. Add to that 5% grade road, and I think extra cooling is helpful.
Jim Lewis
San Antonio, TX
The LVB TSB should take care of any issues with updates. It is overkill to start your truck in the garage to charge the LVB. If you are concerned about wear and tear consider all the other wear and tear you are putting on other components verses just letting your truck sit there
I got distracted by yard work I needed to do...
If I'm damaging my truck, then the Lightning really isn't built "Ford Tough..." I'm 78 years old. In 10 months, I've put 2,500 miles on my truck. If I'm lucky enough to live 10 more years, that's less than 30K miles driven by the time I'm 88. Letting the truck "run" in Full Accessory Mode while plugged into my FCSP and doing nothing in the garage (which is air-conditioned to ~85 deg F in the summer) is probably nowhere near the wear of putting real miles on a Lightning. So, I've got lots of never-to-be used mileage reserves in my truck to keep my LVB charged up. I also got a Ford Protect plan for 10 years, 60K miles. I imagine that will cover compressors and fans, but it probably won't pay much towards LVBs croaking with Ford's not-so-great battery management system. The AC on my 2007 Honda lasted 16.5 years in Texas's extreme summer heat. It only needed to be topped off once with a little refrigerant and ran real cold the whole life of the car. So perhaps the message is that I shouldn't expect the same endurance from a Ford in a moderately air-conditioned garage with fans and compressors hardly having to work to control any low-level electric heat generated charging my LVB.
Even though AGM batteries tolerate deep discharge better than classic lead acid batteries, most advice says not to let them stay long below 50% and that it is best to keep them above 70% SOC. Yet Ford built a system into the truck that will only trigger a recharge within 48 hours if the SOC drops below 40% and only recharge immediately if the SOC reaches 30%. And the truck came with a suspect BSM (with a replacement still on backorder two months later for my truck :rolleyes: ). IMO, it's unfortunate that Ford carried over the ICE vehicle philosophy into its EVs; you have to drive the vehicle to keep the LVB charged up, or otherwise mess around with wires and a battery tender in your frunk, or like me, if you've got miles of life in the truck never to be used, just let it run - only it's in Full Accessory mode with all accessories turned off, and unless Ford Accessory mode is fake, it really shouldn't be doing much of anything except charging the LVB. I only hear a fan running. And the dash message says I can't turn the vehicle on unless I unplug my FCSP charger.
shutterbug
Joseph
Phoenix
Don't know if that changed, by Ford Protect did cover my LVB in C-MAX.
Jim Lewis
San Antonio, TX
In my Ford Protect policy under #7, Items Not Covered, it says the following under subitems s and t:
s) All Wear Items are excluded except when LeaseCare is purchased;​
t) Batteries of all types and cables, brakes (front hub, drums, shoes, linings, disc rotors, pads), exhaust system (includes catalytic converter), and software upgrades;​
My plan is a PremiumCARE EV plan. Under coverage for PremiumCARE, it says the following:
5C. COVERED ITEMS - "PremiumCARE EV"
If You elected PremiumCARE EV, all Failures are covered EXCEPT for
those items excluded in the Provision titled: "WHAT IS NOT COVERED
BY THIS AGREEMENT."
Don't see fans, compressors, and radiators specifically mentioned under What Is Not Covered. One could say that those items would be excluded by term s) as Wear Items, but under the Standard and ExtraCare (lower grade policies), the air conditioning, the radiator, the radiator blower, etc., are all covered. Presumably, that would include the Max Tow Technology package as far as compressor, fan(s), and radiator, too, one would think(radiator and radiator blower mentioned under ExtraCARE High Tech terms). The LVB does seem to be specifically excluded from Ford Protect coverage (term t) but would be covered under a standard pro-rated battery warranty.
The High Tech coverage terms are below. I don't see how that coverage, which would be included in PremiumCARE EV, can cover all those things and not the Max Tow Technology package (except maybe for any software part).
High Tech - Automatic temperature control, air conditioner
accumulator, heater blower motor, heater control assembly, heater
core assembly, radiator, radiator fan, radiator fan clutch or motor,
electronic instrument cluster (excluding the dash pad, clock, audio
and visual equipment), keyless entry system (excluding door
handles), power seat motors, power window motors and regulators,
power antenna, power door locks (excluding door handles and
electronic key fobs), power door lock retainer clip, cruise control
components, anti-lock brake module and sensor, electronic air
suspension (excluding air-lift bags), powertrain mounts.
Henry Ford
If you take care of yourself like you take care of your truck you'll hit 100,000 miles.?
WXman
Central Kentucky
www.facebook.com
2025 F-150 Lightning Flash
Meteorology/Transportation
Aside from cooling, what other mechanical differences does Max Towing package have? Different rear springs? I know about the rear locker. Curious about the springs.
no, there's absolutely no difference in any of these LIGHTNINGS other than the additional CHILLER and Cooling Lines to the battery pack, with the MAX TOW option... the battery is the weak point when heating up when towing heavy loads - the shocks or suspension are no different - the truck, itself, is already built for up to 10,000lb of towing, no matter what trim level - the only difference is the size of the Battery Pack, and the Additional CHILLER.
TOWING TECH is a totally different subject, and/or option...
In model year 2025, the E-LOCKER ONLY comes with the MaxTow option.
And a few other minor features ....
Ford F-150 Lightning MAX TRAILER TOW PACKAGE if not planning to tow? 1756516356839-8f
WXman
Central Kentucky
www.facebook.com
OK, so this is where it gets interesting...
So if the Max Towing package has dual on board charging, e-locker, brake controller, secondary chiller, and possibly larger battery (131 vs. the standard 123 on Flash trim level)? All of that stuff adds weight. How much weight? I have no idea. But let's pretend it adds 250 lbs. of weight.
Well, that's 250 lbs. less payload capacity you will have. And since trailers (campers, enclosed trailers, boats, etc.) are designed to put 10-15% of their total weight on the tongue, that translates to a loss of 2,500 lbs. or more of maximum gross trailer weight.
So, using myself as an example.. my trailer/camper weighs 7,500 lbs. so assuming 13% on the hitch that's 1,000 lbs. Wife, myself, and two big teenagers go 800 lbs. Our coolers and camping gear are 200 lbs. So that's 2,000 lbs. of payload. My truck is stamped 2,030 so I'm OK.
If I had the Max Towing package I would lose 250 lbs. of payload capacity (assuming that's what all the extra Max Towing equipment weighs, which I could be wrong about) so that means that in order to stay within spec I would have to REDUCE my trailer weight, or kick one of the people out of the truck.
So my NON Max Towing Lightning can actually do the job I need it to do and if I had paid extra for Max Towing it wouldn't. Interesting, eh?
Maybe...... depends on each use case, when I'm trailering the race bike, it's generally me and a buddy on occasion, most of my gear is in the trailer, little if any in the bed & frunk, I'd likely still be within the specifications for my 7K GVWR trailer (actual load and trailer are much less though).
The trip is long and requires mid trip charging up to the race track as well as one coming home, having the 'extra' cooling capacity to keep the HVB comfortable during the drive and DCFC session, pays back less time on the plug, if I can get higher throughput with a properly conditioned battery enroute to the DCFC's.
Time has value on my race day, starts very early and ends late. Exactly how much time I'm saving is as debatable as other use cases.
The other factors that I encourage "non towing" buyers to consider are ......
  • What is your long term ownership time frame, is it short?
  • Would having this option enhance future sales potential to the next owner, does having MAX TOW increase trade value of the truck?
SpaceEVDriver
Arizona
You need the max tow package to get the maximum tow rating (10k pounds) and the max payload capacity (2235 pounds). You also need the proper tires. The extra equipment provides compensation for its weight and more.
https://www.ford.com/cmslibs/conten...pdf/2023-Ford-RV-and-Trailer-Towing-Guide.pdf
Ford F-150 Lightning MAX TRAILER TOW PACKAGE if not planning to tow? Screenshot 2025-08-30 at 21.25.35
