- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
Has anyone powered their pool pump from the truck? I'm evaluating the circuits I would need in a sub or generator panel. I don't know that I can make it work with the generator panel. The pool is likely the only 240 device in the house I'd want powered. I know the 5 ton AC unit is out, I likely wouldn't try the oven either.
The pump is a Pentair 011017 Variable speed. They are super efficient, but it is the start up I worry about. They start at full speed and then step down.
Electrical Specifications
Circuit Protection: Two-pole 20 AMP device at the Electrical Panel. Input: 230 VAC, 50/60 Hz, 3200 Watts
EDIT - See post #9 down in this thread for the answer about running the pool pump from Pro Power. TL : DR - you can easily.
