Lightning64
- Jan 13, 2023
- Chicagoland
- '23 Ford Lightning Lariat ER
I’m wondering if anyone else with an F-150 Lightning has experienced their rear window shattering for no reason? I’ve now had to replace my rear window twice, and neither time was it struck by anything. Once in late October and now again in early February (colder months).
The first time it happened, I brushed it off, thinking maybe a small crack had formed from some unknown impact and later failed. But now that my replacement window randomly shattered last weekend while I was driving, I have a strong suspicion that this is a thermal issue.
I believe the problem might be related to the automatic preconditioning system. When the vehicle warms up on a cold morning before departure, it seems like the rear window defroster turns on automatically. Then, when I get into the cab and fully start the vehicle, the defroster turns off until I manually reactivate it if needed. This means the rear glass is potentially going through multiple rapid heating and cooling cycles every single morning, which could be causing stress fractures and eventual failure.
For reference, I have an F-150 Lightning Lariat with the power sliding rear window and rear defrost.
Has anyone else had their rear window unexpectedly shatter? I’d love to hear if others have run into this issue.
Can anyone see in the climate control programming if there is a temperature during remote start that the rear defroster automatically turns on as a convenience to try and defrost the rear window before you leave?
