Tail Gate Automatically Closing. Ford Tech
dtomlin
Cornelia GA
Ford Lightning
I was using my tail gate as a work bench and while I had walked away I think I heard a beep or something and it automatically closed.
Any one from Ford or tech insight have an answer? How to keep it open when being used.
Ford F-150 Lightning Tail Gate Automatically Closing. Ford Tech tgate
Probably a pocket activation. I've opened my frunk several times. You can turn the electric portion of the tailgate off through the truck settings.
TRCarr
Tom / TR
Salmon Idaho now
ā€˜23 Lightning Lariat black
Itā€™s happened several times with my ā€˜23 Lariat 73k miles. But, I admit Iā€™ll have to see it again - with no possibility of fob activation.
TRCarr
Tom / TR
Salmon Idaho now
GoodSam
Good
occupying space
Iā€™d rather it worked like it is supposed to. Sponsored
Funny that it will close with weight on the tailgate. Wonder if there is some 'already in place' amount of weight it will recognize that would stop it from closing? Need to test that.
I tried closing it and then put my hand very lightly on the tailgate, about 2" up, and it reversed. Maybe if no change in weight when closing, items already in place (and sliding to the hinge, lessening torque needed!), it will close. It will reverse if my bed rug gets pinched in the hinge area.
The adjustable Tailgate Boss seems like the best device to use to brace it open:
https://www.ride88.com/product-page/tailgate-boss
Almost certainly a result of FOB button activation. If your truck is capable of Phone as a Key it eliminates this issue.
I think you are correct. It takes very little to turn the gate around once it's moving. It makes sense that it would activate at slightly different weights though. Spray on bedliner or rain are two examples of extra weight that is totally normal. There are others, I'm sure. Neat engineering.
GlitchyTruck23
2023 Lightning Lariat
some
Iā€™ve had this happen several times. My biggest loss was a tumbler of whiskey. I have a 23 lariat and itā€™s very glitchy, especially tailgate operations!
