What is the meaning of the extra mileage counter in the GOM?
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
As the mileage number drops (see pics, it goes from 27 to 10 miles remaining), the second number always shows 70 miles. What the heck is it trying to tell me? I assume it's associated with the icon to the left (a checkered flag??). I feel like this just got changed, probably came with the most recent update I got which updated the icons at the top of the main screen.
Ford F-150 Lightning What is the meaning of the extra mileage counter in the GOM? 1726098621376-m
Ford F-150 Lightning What is the meaning of the extra mileage counter in the GOM? 1726098746096-7u
You have a destination set in your navigation. Or it thinks you do.
If you have a destination set in the navigation, cancel it. If you don't, create a destination and then cancel it.
I use that information to determine if I could make it to the destination, in the photos shown, you should be looking for a charging station with only 27 & 10 miles of range remaining.
Sometime NAV sets' up a destination based on prior driving patterns if you selected the recommendation in error cancel it.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
70 miles to your programmed destination in your GPS
Assuming there was an intentional destination set, shouldn't the distance to the destination have changed with the distance traveled between the pics? That seems odd. I've only used the nav to set a charger and that bottom number usually updates as I get closer.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Note the other data on the screens, it wasn't the same trip, prohaps not the same day?
mb0220
Matt
2022 Lariat ER
On a related note, it seems (perhaps due to a recent Android Auto update) that "distance to destination" number shows up when using Google Maps. Used to be only for Sync Nav. Unclear as of yet if it updates range based on your route like it does with Sync, but I doubt it.
Curiously, when I use Waze that number also appears in the display but it's always zero.
Confirmed that the 6.14.0 update brought this enhancement, first time I've seen it.
MADequipment
Huy
F150 Lightning Lariat Avalanche Gray
In addition to Google in Android auto, for those with iPhones, Apple Maps will give you turn by turn and distance to destination on the dash in addition to center screen data. It does not work with Google maps on iPhone.
