tonesto7
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
Second that, this widget is great all around!
I almost can't really call it a widget anymore because it's basically an app.
I plan on expanding on the interface as time and ideas come along
tonesto7
tonesto7
Anthony
Are you able to install the new version? I'm still getting the iCloud error. ??‍♂
Check your iCloud settings in iOS where you can toggle on/off individual apps for iCloud. And make sure Scriptable toggle is turned on.
Jaug
Jason
Fargo
2021 F150 Platinum
Having the same issue with iCloud. iCloud is on and the scriptable app is toggled on within iCloud settings. Deleted and reloaded scriptable multiple times. Hoping someone figures this one out cause I would love to try this out.
JediNut
Emmett
Rocklin, CA
'21 Ford F-150, '05 Harley Davidson Softail Deuce
When I was having issues, I deleted the FordPass script in scriptable, then went to the "Files" app, went into the Scriptable folder and deleted the "FPWModules" folder. THEN, I went back into scriptable and used the "FordWidgetTool" to get the latest beta version.
tardman91
Matt
Odessa, FL
2021 F150 STX
It is
I deleted it and reinstalled a couple of times and also toggled it on/off I. The iCloud settings.
I checked my Files app and didn’t have a scriptable folder.
shacky4
Scott
Sault Sainte Marie, Michigan
2021 Ford Bronco, 2018 Ford Escape
Same here, medium works but the large won’t load.
I'm using the large one. It takes a bit of fiddling sometimes to install. It just doesn't want to load the script at first sometimes. If you go to the settings and view the widget in the large size and then close it, the widget seems to load and have no further problems. If that doesn't work, remove the widget and reinstall, try the settings view again.
Way2qk4u2c
Michael
Austin
2021 F-150 2015 Mustang GT
Network admin
@tonesto7 thanks man for all your hard work! Love the widget. I went to update to your latest version and now receive this error. Any ideas? Unable to import a module? I used the ford tool widget to auto install the update.
Ford F-150 Lightning FordPass - Scriptable Widget (iOS, iPad, MacOS) EB1E95C2-4738-4ED9-A02B-62C319ACCBD9
Lugusthedog
Lugus
Sun City Arizona
2021 F150 Platinum Maxtow 3.5 EB
I am getting exact same error.
shacky4
Scott
Sorry you are having that error. By no means am I an expert on this or involved in the widget. But, just a couple quick suggestions. Check to see that the widgettool is updated. It should be 2.0. Try removing the widget and re-adding it. If none of that works. Remove the widget, uninstall Scriptable and start from scratch. I have found that sometimes it takes a bit of finesse to get it running properly, but once it does, I haven't had further problems. Hope that helps and be sure to re-read the second sentence of this post.
trojandawg3
Shannon
Northeast Georgia
2022 F150 XLT 302A FX4 SuperCrew 3.5 EB
Industrial Automation Specialist
I've tried all this multiple times with no luck. Anyone else having luck with the large version?
I'm putting detailed in the parameter.
tonesto7
tonesto7
Anthony
just ignore the large widget for now. I need to track down the cause of issues.
tonesto7
tonesto7
Anthony
So I
Large has been working for me.
This has been what makes me the most furious. It works sometimes, then others it works partially or not at all.
If I remove the buttons on the large widget it refreshes every time. So something in that section is causing problems. So I need to dissect that code and see what I can find.
