Well… umm I was worried that maybe my voltage was too low on last updates. So during this one I’ve kicked up the battery maintainer to 20 amp. Don’t know if that’s the best idea but… we’ll see.@jmm3807 I see in your most recent pic you have FDRS showing 13.4V. Is that from running of the recommended charger? Whenever I have mine plugged in I hover right at 12.6 to 12.7. Just curious how you got the higher volts that's all.
Just my old man way of looking at it, but with a Nano you simply use FDRS + Forscan to have a poor man's Mongoose.You can safely do these with the Nano, just DO NOT perform Network Scan in FDRS. Follow steps documented here and you will be fine!
It'll do the Fix Me test and was pointed out by another userThe fourth test is debug. I doubt anyone doing this work will care.
I re-ran your vin this morning. You have a few more updates available. Good luck at the dealorHere's my VIN if someone could check, thanks 1FTEW1E86MFC76534
If his charger has a power supply mode, which is the preferred mode if you have it, then this is probably about right. My NOCO in power supply mode is programmed to maintain 13.6V.@jmm3807 I see in your most recent pic you have FDRS showing 13.4V. Is that from running of the recommended charger? Whenever I have mine plugged in I hover right at 12.6 to 12.7. Just curious how you got the higher volts that's all.
You found the fix me button when you and I were on the phone. I don’t remember you running the debug. But if it worked, great.It'll do the Fix Me test and was pointed out by another user
Welcome back @iceman77 !NOTICE: I have updated the guide to reflect the changes to the preferred VCI device being the Mongoose-Plus as well as well as posted warning not to perform Network Scan if you decide to stick with the VCX Nano device
I apologize for the delay, I have promised to update the guide a week ago, but after 2 years of avoiding the COVID plague, this time it got me and hit me pretty hard![]()
The camera module is a baby compared to the IPMA. Just wait. You have just won the pie eating contest. Your prize is more pie.Minute by minute…
Cruise control module, done.
Power steering control module, done.
Driver status monitor camera module, step 2000 of 16430… literally. This will be a while. It
