Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
I initially got a 50% battery charge reading when I connected up the ProLogix charger/powersupply to mine, and it took maybe 5 minutes to get to full charge.Hey guys, I'm FINALLY starting this process with the Mongoose on a powerboost and I have yet to get anything updated, just got to the step where I have the toolbox open in FDRS and then I'm supposed to hook up the battery charger. I did that and I'm reading a low voltage - started at 11.9 and is now at 12.1 after waiting a while. I'm using an 8 amp charger. 2 questions - why the hell would my charge be so low on a new truck? I keep the key fob in the truck all the time, would that do it? Or is it a bad battery? I drive the truck every day. Also - is charging this thing at 8 amps going to take as long as I think it's going to? Maybe like 6 hours or so?
I would not attempt to do these updates without the minimum Pro-Logix PL2320 20A charger (or equivalent) to keep the voltage up while programming.
Keeping your fob in the truck would not cause the battery to drain as far as I know. Although it might be keeping it from going to sleep completely. Not sure on that.
