Charge Station Pro Problems
CTBob
Bob
Connecticut
2022 Lightning
I think I was one of the first to report the phone number to call to get of the update list. Glad it is working for everyone, but as one who did not get valid password correction, I am not able to benefit from the wifi update. I have called and called and no one seems to have a solution. Ford keeps telling me they will have someone call me back, but they never do. If anyone else had a problem with their password or was able to decode their Access Code for a password to solve the problem let me know. Thanks.
ChrisCon
The Hamptons, NY
CTBob , can you private message me a photo of your access code? Maybe I can help
FlasherZ
St. Louis Metro
Last night I unplugged and saw my FCSP lighted up white again, which tends to happen only during setup and when firmware is downloaded. No change in the firmware version this morning, but I think it took a couple of days last time it did that. Perhaps new software inbound to restore the insights?
Marcoux
Stéphane
Ontario, Canada
F-150 lightning XLT
I don't know about that. Since I got the update, the charge station turns white every time I unplug it from the truck. I'm starting to think that it turns white when it's communicating with the app to update the insight...
RainorshinePNW
Well, things are definitely better these days, but not perfect. Plugged in about 1130 last night when I was down to about 50%. Target is 90 by 8am, still set to 80 amps. Not sure why it thought it'd have to charge outside my set hours (11pm-8am) to get from 50 to 90. Threw an error at 3am, but must have reset and kept going. Looks like it finished OK.
Ford F-150 Lightning Charge Station Pro Problems markup_1000000048
Ford F-150 Lightning Charge Station Pro Problems markup_1000000047
RainorshinePNW
The mystery deepens... Looks like it finished charging to 90 at 230, but threw an error at 330? 🤨
Ford F-150 Lightning Charge Station Pro Problems Screenshot_20220820-105834
Firestop
Firestop
Had my FCSP installed 4 days ago and noted it had software version #.###.63.#.###.#.##.#.##.#.##
Question: Is this the latest version of the FCSP software?
EVSE Software Version
2.112.68:2.127:1.10:0.31:0.40
RainorshinePNW
I believe so, yes- at least that's what mine is at too
FlasherZ
St. Louis Metro
Interesting - when did you receive your FCSP? Mine arrived with .64.
.68. is still the version that I'm on - and insights seem to be working, although it only seems to update after you unplug the vehicle (which is weird).
Firestop
Firestop
I recdived it on 8/3….installed on 8/18 and connected to the internet. It updated to .68. software sometime yesterday while the truck was unplugged……all charge events have always been present….
OB121
Bay Shore
2021 Bronco Outerbanks Sasquatch, 2019 Expedition
I'm seeing version 2.112.68.2.127 as of today but ford pass will not let me increase my rate from 64 back to 80. Keeps failing. Rebooting the device doesn't help either. May have to take the case off the device and do the reset.
I was having the same issue. I had lowered it to 72amps in July and then could not change it back to 80 no matter how many times I tried. I tried again today while it was in operation charging the truck and it changed successfully.
LightningMcqueen
Justin
Austin,tx
2017 F150, 2021 Bronco Sport
I am still getting the error messages whenever I charge. I wish they gave more information than just "Something went wrong and your charge station can't charge your vehicle. Open your charge station settings for more information"
But there is no information in the charge station settings.
I have Software Version 2.112.68.2.127:1.10:0.31:0.40
Truck does end up fully charged in the AM.
Griddlez
Griddlez
Metro-East of St. Louis, MO
Mine eventually let me change the setting the next day without having to do any kind of reset. Has worked like a champ since.
Maverick87r
Randy
F 150 Lightning
Still struggling to get the update or even try to find it via the charge station pro app it never picks it up if I wanted to reset. On v64 and was overheating so went down to 60 amps and unable to change. I tried the red button with a power cycle but then just goes back to blue lights.
