jallen
I’ll do the screen one…sounds simpler through ForScan. But, still need the module the heated steering wheel plugs into. There is currently a “dummy” connector there now that I plugged into while swapping.Just cause I’m curious, you mean the hvac module?
OP, have you looked through the 14gen forum thread for the heated wheel retrofit? There is an option over there to enable the heated steering wheel via the screen and not the hvac module. I haven’t tried it yet but would be interested to see if it’s available on ours as well.
