SmoothJ
- First Name
- John
- Dec 22, 2021
- New Jersey
- 2022 F150 Lightning
I was looking around online, and may have found a new priority update from FMC. I don't recall reading about this one either. I also attached the PDF, which doesn't explain anything... like usual.
Manufacturer Communication Number: 23PU0306BCDET
Summary
Priority Update 23-PU0306-BCF-DET for 2022-2023 F-150 Lightning vehicles is now available.
Quality Improvements include:
- Removes erroneous "Air Dam Fault" pop-up message
- Improved accuracy of displayed range after AC charging
- Correction a condition where for cabin-preconditioning & heated steering wheel may not be working properly
- Improved route based energy predictions to recommended battery cooling based on expected thermal loading.
-Charger locking pin robustness improvement (retract while off plug)
-Improved 12V battery drain by decreasing the frequency of the vehicle waking up.
-Shorter time to engage electronic park break after drivers door is opened.
- Displayed motor temperature will now increase more gradually.
- Distance to Empty algorithm improvement.
-Improvement to calibration of brake fluid viscosity algorithm to prevent false DTC detection at cold weather
-improved brake bleed quality
Summary
