Ha ha...I just figured this out as well. Maybe the fob doesn't have to be in the truck?Also there is a setting on the truck to disable the shutdown timer
Our power came back at 4:43 am and I got up and switched back to the grid at 5:24. Wound up using just under 12 kWh for the approximately 10 hour outage. I did forget to turn off the auto headlights so some of the energy was wasted lighting up the garage. Plus my wife got a good laugh when she checked the security camera video of me wandering around the garage in my underwear this morning.The thunderstorms that moved through the east coast this evening knocked out our power about 7:30. This is the first long outage I’ve had since installing the switch and it is working great three hours in. I forgot to turn off the auto shutdown timer and it is still on. Did one of the recent SW updates remove the shutdown timer when ProPower is active?
Aren't both the Generac 30A & 50A MTS both limited to 50A on the utility side according to the specs: https://www.generac.com/generaccorp...wer/homelink/homelink-spec-sheet_0l1648_1.pdfOne note on the 30A Generac MTS is that the max amperage for the bus is 50A, which limits what you can power from the grid (what circuits you can put in the panel). For me that meant I could not have either my water heater or stove top in the MTS, even though I could manually manage the load while running off ProPower. I should have opted for their 50A MTS...
It’s useful if you have more than 30A worth of loads that you can manually shed or alternate between when running on the truck.Aren't both the Generac 30A & 50A MTS both limited to 50A on the utility side according to the specs: https://www.generac.com/generaccorp...wer/homelink/homelink-spec-sheet_0l1648_1.pdf
From what I can see it looks like the following difference:
-$200+
-50A vs 30A inlet
-Conduit size
-Different bus bar to allow for more tandems? i.e. 10 circuits vs 16 circuits on 50A.
-Additional breakers via tandems
-Wiring sized for specific breakers?
The automatic transfer switch PN is the same for both units and they share the same manuals. Is there something missing or am I correct that the 50A version wouldn't have helped as it is still to limited for you on the utility side?
I’m putting in a standalone transfer switch and separate subpanel. Everything is rated 100A and the subpanel has 20 spaces. I’ll have 2 fridges, freezer, gas furnace, gas range, microwave, some kitchen receptacles, fiber modem, dishwasher, and some lights. I’ll post a write up when I get it done. Everything is done except pulling the wire to the garage.On so you wish you had more options/circuits to control what to shed? My goal is only fridge and deep freezer and some plugs. My panel is full as it is, so I am using this as a pricey sub panel that allows for a generator. I need 4 slots free 2x EVSE and 2x for sub panel.
I was told (or assumed?) the 50A unit had a bigger bus bar an larger mains wiring. I thought the system used a 70A breaker?Aren't both the Generac 30A & 50A MTS both limited to 50A on the utility side according to the specs: https://www.generac.com/generaccorp...wer/homelink/homelink-spec-sheet_0l1648_1.pdf
-$200+
-50A vs 30A inlet
-Conduit size
I will be the first to admit I misread or misunderstand somethings. I was curious about the larger breaker as well, though every thing I have read seems to indicate the 30a and 50a are the limitations on the generator and both are limited to 50A on the utility supply. I would love for you to prove me wrong.I was told (or assumed?) the 50A unit had a bigger bus bar an larger mains wiring. I thought the system used a 70A breaker?
You appear to be correct. All five models require a 50A main breaker; https://www.generac.com/generaccorporate/media/library/content/all-products/portable-recreational-power/homelink/homelink-spec-sheet_0l1648_1.pdfI will be the first to admit I misread or misunderstand somethings. I was curious about the larger breaker as well, though every thing I have read seems to indicate the 30a and 50a are the limitations on the generator and both are limited to 50A on the utility supply. I would love for you to prove me wrong.
I think the big difference in the bus bar is the allowance for more tandems in the 50A version. The automatic switch PN is the same and my assumption is the manual switch may be where it is limited?
Do you mind sharing the details of your configuration? I’ve been in a protracted discussion with my electrician over installation options as you briefly described. Thanks in advance!I’m putting in a standalone transfer switch and separate subpanel. Everything is rated 100A and the subpanel has 20 spaces. I’ll have 2 fridges, freezer, gas furnace, gas range, microwave, some kitchen receptacles, fiber modem, dishwasher, and some lights. I’ll post a write up when I get it done. Everything is done except pulling the wire to the garage.
You must have missed it!Do you mind sharing the details of your configuration? I’ve been in a protracted discussion with my electrician over installation options as you briefly described. Thanks in advance!
Yep…I’ve been off the forum all summer. Thnx for the link!You must have missed it!
https://www.f150lightningforum.com/...p-power-installation.16542/page-2#post-333649
