So you are simply using the battery clips to hold things on?I did not remove the under cover. I raised it, attached the charger’s clip and repositioned it as low as possible. It will not go fully back into a closed position, but it did go down low enough to reinstall the fender cover.
That red post cover can be removed, but I’m sure it can be done without the appropriate tool. Or least not without breaking it.
You may have seen that the positive post is is not actually a ‘post’. It is an anvil shaped connection piece, so to answer your question directly, I don’t think you add a lug to attach a terminated positive lead.
