Priority Update: 23-PU0722-DC-CHG3
BennyTheBeaver
Recieved this update on the 8th. Thought it was an old one I'd finally recieved but this seems new as I receieved it after updating everything else with FDRS. Looks like the Mach-E recently got it. I haven't Fast Charged since receiving it so I can't comment on what this does.
Ford F-150 Lightning Priority Update: 23-PU0722-DC-CHG3 Screenshot_20231210_150317_FordPass
BennyTheBeaver
BennyTheBeaver
I noticed this is a [23] version of what is discussed in an older thread:
https://www.f150lightningforum.com/forum/threads/priority-update-22-pu0722-dc-chg3.16534/
I've locked that thread to move active conversation on this variant, if by chance folks are still getting the [22] version let us know here, I could reopen that thread if needed.
I noticed that as well. The 22/23 refers to the year it was released. In the thread that tracks the Mach-E updates...this was one of the more recent ones.
COrocket
F-150
I really hope that Ford one day unlocks 200+ kW charging in this or another update. (If the truck has the wiring to support it) The Lightning really should be able to take advantage of higher charge rates with a relatively large 130 kWh battery.
Puffoluffagus
Tyler
Georgia
23 Lariat ER
Just got this update as well. Was updated to 6.4 yesterday and then received this today
KurtsRPMGarage
Kurt
Orange County, CA
Have this scheduled to install tonight. Been getting lots of updates recently which has been great. However, I still don't have the little charge percent on my instrument display. What the hell!
invertedspear
AZ, USA
lightningcalcs.pages.dev
Updates are, unfortunately, not always cumulative. So if you miss an update, you might get other updates, but it doesn't reach back to grab what you missed. Honestly as a Software dev, this is a maintenance nightmare as every "update" can't depend on functionality of previous updates already being installed. But it makes the most out of limited bandwidth or metered connections. There really should be a way of saying "when on my wifi, please pull any updates I'm behind on" but Ford will do as Ford does.
That’s not possible. The highest amperage chargers are limited to 500 amps. The highest battery voltage on our trucks will run about 385, so 385 x 500 = 192.5 KW. A discharged battery will be even lower voltage.
The battery capacity has nothing to do with it.
Yellow Buddy
Smart Ass
Or hold the charge to 90% instead of 80%.
I’m personally quite happy with the way the Lightning holds the curve up to 80% it’s less peaky than others. Just wish it would hold it for another 10% or a couple more Amps during that period either one would help quite a bit.
COrocket
F-150
So just installed this update and had a code brown - power was reduced to 56% for the first drive after install. But a power cycle of the truck fixed it thankfully.
Also if you install manually instead of scheduled, it seems locking the doors when I left the truck in the driveway interrupted the install process. The 12 minute install failed a few times this afternoon when I left the countdown screen in the car and locked the doors. Third time I just walked away from the truck after closing the door and the install was successful.
roadhouse
F150 Lightning Lariat ER
Got this one this afternoon. Similar to other people - got 6.2 about 10 days ago, 6.4 a week ago, and this one today. Seems like the update frequency is starting to ramp up which is good!
Minh
Minh
NJ
Hello,
anyone having issue setting charge limit after receiving this OTA? I always have mine set to 90% but now it just keep showing target charge 100% even after resetting my charge location and preference.
Hello,
Delete the charge profile, rebuild a new one from scratch, this has happened in the past on other updates.
Minh
Minh
NJ
Yes , deleted my charge location and had to replug so it detect the location again and redo the charge profile. But now I see it did stop at 90% charged however the app screen show target charge level 100%.
Ford F-150 Lightning Priority Update: 23-PU0722-DC-CHG3 IMG_9269
Wait a day and see what happens, or try clearing your cache on the Fordpass app (DO NOT DELETE CREDENTIALS) or you screw up your PAAK, then, force stop restart.
Hopefully the next charging event will document correctly, assuming the limitation of 90% took in your rebuild.
