This is an update for the driver facing cameras, so only BC equipped vehicles will see this OTA.Is this a BlueCruise only update? Has anyone that doesn’t have BlueCruise gotten this update?
When are your trips?So after calling the BEV Hotline I was advised to bring it in to the dealer. The dealer says it’ll be $190 just to check because the Lightning is not part of the Mach-E TSB @Ford Motor Company.
Normally I wouldn’t bother but with Blue Cruise being disabled and trips coming up I want to get this fixed.
I’m really thinking FDRS cable might be worth the cost now, especially if these updates are prone to disabling key components of the truck or tend to fail.
smh, disappointed
Next weekend for Easter. They are currently checking to see if it can be covered.When are your trips?
smh, disappointed
Did you have the broken BlueCruise problem since update 6.13? If so, did it finally fix the problem?FWIW, I was pushed this update yesterday. It failed installation overnight. Could be because I was on low charge, not sure. I tried again today, this time unplugging my charger before starting the update, and it installed with no issues.
No I don’t have the issue. I had a broken BlueCruise a long time ago, and had someone log into my system while connected with ForScan and they fixed it up. Not sure if that insulated me from 6.13 issues or not.Did you have the broken BlueCruise problem since update 6.13? If so, did it finally fix the problem?
I received Powerup 6.8.0 yesterday.Anybody get this update?
