OG_Ragnar
- First Name
- Brandon
- Apr 8, 2024
- Southern Wisconsin
- 23 Lightning XLT ER, 17 C-Max Energi, 15 Flex
- Occupation
- Nonprofit Administration
Thanks, I think you may be right about the specs of my unit. I do remember the Clipper Creek website claiming the unit would charge the Lightning ER at 19.2 KW which is why I chose it. 15 would be great, but it 13 seems to be working OK so far.I think the Clipper Creek is a 64 amp charger on an 80 amp circuit that can charge at a max rate of 15.4 kW. You should be able to get more than a 13 kW charge rate but probably not the max charge rate of your truck. This is based on the current specs of this charger now that Enphase owns them. Your Clipper Creek model may have different specs.
