ThunderSnoww
- First Name
- Kevin
- May 2, 2024
- Detroit, MI
- 2023 F-150 Lightning Lariat ER Antimatter Blue
After a four-week delay in getting my coupon to buy my FCSP via Ford.com, I finally got an electrician to install my FCSP today. At the end of the installation, the installers tried to help me link the charger to my FordPass & home wifi via the Ford Charge Station Pro Siemens AG iOS app. Initially the SSID showed up correctly on my iPhone and I added the SWAXXXXX "network" through iOS wifi settings per the app's directions. My phone recognized the charger and then communicated with the home wifi at first, but eventually, the connection failed. I knew I should have moved my wifi router closer before installation, but was hoping to skip the hassle and just be within range. Bad choice...
After relocating my home wifi router to within a few feet of the FCSP mounted to the side of my house, I then had to navigate through numerous router issues. Eventually, I finally got my home wifi back up and running after two hours of messing with the modem and factory resetting the router. I left for dinner, came home a couple of hours later, and then tried to re-add the charger via FCSP Setup App. This time the SSID never showed up as an option. I tried power cycling the charger at the service panel breaker and then waited 3-5 minutes per other troubleshooting posts before re-attempting the "New Station Setup" in the app. I tried several times to manually add the SWAXXXXX SSID and it never took.
Any ideas on what to try next? I saw that I should try hard-resetting the FCSP, although I'm not sure exactly how to do that. Is there a way to clear the network settings from my iPhone so that way the phone doesn't keep ignoring the network? Is there a silver bullet to this issue that can prevent me from wasting my life on the phone with tech support come Monday?
TIA
TIA
