Sorry - 1FTVW1EL4PWG07913VIN is missing a character somewhere.
Gotcha, thanks @rugedraw !What that refers to is that Ford is aware that even if you are on the latest Sync version, there are some issues with phone connectivity and other bugs which they are hoping to address in future update. So yes, I another update for the APIM is coming, but you will need the one(s) before it before you can get that one whenever it gets released. They have to be installed sequentially.
What you're seeing is what we playfully refer to as a "phantom update" over on the F150 forums. There is no active OTA trigger for your truck at this time. Ignore it.....it will eventually go away.Could you please take a look at VIN 1FTVW1EL3PWG41194 ? I was getting updates pretty frequently for two weeks. Then last week I received notifications 4 times that there would be an update overnight. It would not tell me what the update was and would not let me install it immediately. Said it would install at 1am but never did. Just had the same notification today and am wondering if updates are failing or something.
Thanks!
Thank you for checking. I was optimistic that I was getting caught all the way up. Back to waiting…What you're seeing is what we playfully refer to as a "phantom update" over on the F150 forums. There is no active OTA trigger for your truck at this time. Ignore it.....it will eventually go away.
Just received a text from the dealership saying that there is a GVMS warning, which indicates a concern with data on the server for that module. They have contacted Ford and they are passing it over to the module programming team to check on it. And it make take some time, but sounds like it will be a while before Ford has a chance to look at it.They haven't updated a thing. Unfortunately, I have seen this happen way too many times to count. Nobody likes to work for free, so I don't blame them. Service advisor probably doesn't know what's going on. When you call, he'll ask the tech it is assigned to and the tech will say he did everything, which your advisor will relay that to you.
I don't have access to FDRS right now to verify that, but that can very well be true.Just received a text from the dealership saying that there is a GVMS warning, which indicates a concern with data on the server for that module. They have contacted Ford and they are passing it over to the module programming team to check on it. And it make take some time, but sounds like it will be a while before Ford has a chance to look at it.
should be GateWay Module GWM ?GVMS warning
I’m not sure. Here’s the full message that they got from the “Ford hotline”.should be GateWay Module GWM ?
