Priority Update: 24-PU0105-CMR-FX. Driver Monitoring System
Is this a BlueCruise only update? Has anyone that doesn’t have BlueCruise gotten this update?
This is an update for the driver facing cameras, so only BC equipped vehicles will see this OTA.
F150ROD
U.S. Navy Retired
So after calling the BEV Hotline I was advised to bring it in to the dealer. The dealer says it’ll be $190 just to check because the Lightning is not part of the Mach-E TSB @Ford Motor Company.
Normally I wouldn’t bother but with Blue Cruise being disabled and trips coming up I want to get this fixed.
I’m really thinking FDRS cable might be worth the cost now, especially if these updates are prone to disabling key components of the truck or tend to fail.
smh, disappointed
Gimme_my_MME
smh, disappointed
When are your trips?
F150ROD
U.S. Navy Retired
Next weekend for Easter. They are currently checking to see if it can be covered.
Im sure this will happen again, so I will be investing in my own Software Update methods.
I’m sure it’s probably the SA that just doesn’t know. On another note the Bronco Raptor sure is nice
Ford F-150 Lightning Priority Update: 24-PU0105-CMR-FX. Driver Monitoring System IMG_1132
Ford F-150 Lightning Priority Update: 24-PU0105-CMR-FX. Driver Monitoring System IMG_1131
Update: SA said there will be no charge….
Biggie
Socal
F-150 Lightning Lariat ER
[/QUOTE]
smh, disappointed
Can you please update us when you get your truck back from the dealer? Did they install this update for you? Did it successfully fix your broken BlueCruise? Thanks
mtxmiller
Corning ny
2022 lightning lariat ER
Mine went to dealer and back today for same issue. They ordered new driver facing camera module.
G-Zeus
Garth
Massachusetts
F150 Lightning Lariat SR
FWIW, I was pushed this update yesterday. It failed installation overnight. Could be because I was on low charge, not sure. I tried again today, this time unplugging my charger before starting the update, and it installed with no issues.
Biggie
Socal
Did you have the broken BlueCruise problem since update 6.13? If so, did it finally fix the problem?
G-Zeus
Garth
Massachusetts
No I don’t have the issue. I had a broken BlueCruise a long time ago, and had someone log into my system while connected with ForScan and they fixed it up. Not sure if that insulated me from 6.13 issues or not.
Bdavidk
2022 Ford Lightning
Contractor
Anybody get this update?
Ford F-150 Lightning Priority Update: 24-PU0105-CMR-FX. Driver Monitoring System IMG_3464
flyin525
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
Yes, CMR-FX has been out for about a month now
Watt2Go
VT
2021 Mazda CX30, 2022 Ford Lightning Lariat
Retired IT
The latest update I have showing in the Fordpass App is 24-PU0105-CMR-FX installed on March 1st. A few weeks ago I got in the truck and noticed my folding mirrors did not unfurl when I started the truck. Found my auto-fold setting had changed to off and also noticed my Autohold setting was off. Looked for an update, saw none and just kind of noted it. Today I swear the chimes sound different in the truck for things like keep your hands on the wheel, look at the road, etc. Again no update showing. It's like little software elf's play in the truck at night ;)
TheBigBezo
Earth
I just got this update today. Have had no issues with BC nor do I think I ever received 6.13.0. I'm usually behind folks here by a few months when it comes to updates. No issues with the install.
I wonder if anyone else is in an update tranche with me.
