Spilled 3L of water inside truck - where'd it go?
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
Maybe dumb question... but it's a Monday.
Two nights ago I packed the truck for an early morning mountain bike outing. Filled up my hydration pack with 3L of water and placed it on the passenger seat. The next morning (yesterday) I found that the valve was pinched and the entire pack emptied. I saw a couple small puddles on the weather mats (not that much - less than a liter). Didn't see any water on the garage floor. Removed weather mats and didn't see any more water. Where did it all go?
I assume there is drainage built into the F150 interior floor? I'm guessing/hoping that it did all drain and the garage floor simply dried up overnight. I was a bit mystified! Any chance some of this water got into undesirable places?
sotek2345
Engineering Manager
At a minimum, I would check to make sure it isn't absorbed into the passenger seat cushion.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Probably not drained. Most likely soaked into the cushions as mentioned.
Would be a bad design if the rubber floor if the Pro doesn't drain itself well. That is kind of the whole point of the rubber floor to not worry about how much mud and slush get tracked into the truck - should be able to just wipe it out and not worry about any wet soaking in.
There's no drainage built into the floor. It's in there somewhere, or it evaporated. Or a combination of both.
rio
CT
Thanks guys! I'll inspect the seat cushions.
rio
CT
I'm sure you'll find it sitting on the metal under the flooring/padding. just slowly getting into every electrical connection lol
Thanks. Laugh it up!
You might want to use the AC & Heating system in the truck to dehumidify whatever isn't sopped up once you find it in the lower floor, cable runners, seat, etc
Revenge
Ryan
2023 Lightning Lariat SR, 2011 Flex
Check under the door seal where all the wires are run. Other people have mentioned water leaking into the cabin and accumulating there.
rio
CT
Thanks. I checked under the door seal trim and got to feel that the cloth liner under the vinyl floor is very damp. It's not saturated and there's no water pooling in the cable runner, but definitely very damp. I'm not sure how to expose it in order to dehumidify it. Peeling back the vinyl floor seems like would be a big pain.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Don't use heat as it can turn to mold.
Place a good running fan and direct it to the damp surfaces. It will help dry things up. Of course a dehumidifier will too if you have access to 1.
Rick
rio
CT
Rick
Thanks. Most of it seems to be the insulation under the vinyl floor, which seems very difficult to expose. For now I have the AC on all day so see if it makes any difference. I need to see if it's worth ripping out the floor which might be a major PITA.
I suggested heat to stimulate an evaporation cycle within the cabin, you could park the truck in full blazing sunlight with the AC running to get that moisture to evaporate faster, your AC will condense it from the air, expelling it from the HVAC housing to the ground below the truck.
