F150 Lightning FORscan thread
Have you tried "headlight calibration" via FORScan?
No, and didn't even think of that, tbh. General rule of thumb is to try the easier things first, so I will. I plan to mess around a bit tomorrow since I'm off.
marc088
Marc-André
2024 XLT
I just did it for my 2024 XLT, it’s about 500 for all parts and a few hours of your time. Find the thread called diy adaptive cruise control install by brotato and Hhunterfamily on this forums all instructions and all problems you will encounter will be there.
Thanks!
B177y
Olympic Peninsula WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow, 2021 Highlander V6, 2013 Suzuki Wee-Strom
Coffee Roasting
I had to get a test version of forscan, but I now have the glare-free lights working. Followed OP instructions and ran the headlight calibration. They still move smoothly, no issues that I can tell.
2024 Pro SSV (the "police package"), max tow, pro power, dual charger
vLinker FS USB connector
Well, I didn't get a chance to mess with it yet, but the movement of the lights is jolted and not smooth or fluid. Also, they turn off sometimes even when there are no cars coming in the opposite direction. I live in the city where it is bright and it is rare I am in an area dark enough for them to come on. It's hard to describe the behavior, but I can tell you when I first enabled them a while back ago, it worked REALLY well and now it doesn't, so something isn't right somewhere.
Did you do any investigation this weekend? I made a post a few weeks back about the behavior changing. The lights used to have a very smooth change to them, you could see the blend. That is no longer the case. My last trip you can see the pixels actually turning on and off as the lights change now. It's rather blunt, no longer smooth. I don't know where or how, but I'm guessing Ford has updated an underlying module or piece of SW somewhere.
I didn't really have any unexpected behavior, but the blending is no longer smooth. I haven't had Forscan plugged into the truck in a while, so I know I didn't make any changes to affect this.
I did not. I was planning on messing with it at my buddy's house, but when I got there, it was beer o'clock and before you knew it, the sun was going down and I didn't do a damn thing. lol
I've read that too; about the movement of the lights being blunt now with newer software. I'll get to messing with it eventually and report back anything I find.
I enabled glare free before my truck received its first update, mine have always been abrupt. Each segment immediately disables and then will fade back in very quickly.
The bending is smooth and rapid.
CRAIGC540
Craig
Moreno valley
Technician
I've seen a video of a lightning dash cam with glare free and it showed the black box effect going in and out.` Is this what you mean by blocky? and which is normal? Mine is smooth but I only notice it on the side of the road and not in front or behind any cars.
I've seen a video of a Lighting dash cam with glare free and it showed the black box effect going in and out.` Is this what you mean by blocky? and which is normal? Mine is smooth but I only notice it on the side of the road and not in front or behind any cars.
I have noticed it down the center but it's less obvious, to the sides is certainly more obvious.
Mine disables in specific segments, if I had to guess I would say maybe 10 or so separate sections that turn on and off
21st Century Truck
Martin
Somewhere I read that it's supposed to be 16 sections (one section for each horizontal LED in the high beam). Can't remember where I saw that now.
I would have thought more - an 8 by 10 or 8 by 8 matrix at a minimum. Truly cauldn't count, but I do know you can see the pixel shape and not smooth like it once was.
Entropy
Michael
Boston, MA
'24 Lightning Flash; a few others
Working to pay for college tuitions and fishing trips
Successfully did anti-glare on 2024 Flash last night. Confirmed the bending light still works too. Awesome feature, thanks for the info!
I am attempting to do the same on a 2024 Flash, but when I try to edit IPC lines per the OP, it gives only the option for an odometer write. I cannot get to the settings below. Were you able to?
IPC720-01-01xx8xxxxxxx--
IPC720-10-01xxxxxxx3xx--
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Can anyone confirm if the latest available FORSCAN version 2.3.63 can communicate with 2023 Lightings? I tried to edit some settings months ago but forscan was unable to communicate with the truck. I know at the beginning of the thread it says to contact forscan for a beta version, but thats 2022 info.
Entropy
Michael
Boston, MA
It communicates with my 2024 , so presume it should with a 2023.
21st Century Truck
Martin
Yes it does.
B177y
www.ptcoffee.com
Coffee Roasting
When you say "communicate", I think that has more to do with having a quality OBD adapter that is recommend by ForScan and a working laptop.
I have a 2024 Pro. ForScan communicated through my adapter and allowed me to make some changes to modules, but it wouldn't write my changes to the IPMA module. I had to get a test version of ForScan, and that version has worked on all of my module changes so far.
So, you may have "communication", but could also need to troubleshoot and get a test version of ForScan through their customer service. Most trucks work just fine with ForScan, sometimes you get lucky and have the truck that needs an update to ForScan.
