mrau
23 Lariat⚡ER
I haven’t gotten any CSP notification (ford.com or when logging out/in to the app
Can't recall if Ford sent a notification.
However. if you have a CSP it should show in Ford Pass app under the "Service" tab. If present, then just touch the "Customer Service Program(s)" button to see the details.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks IMG_3118
Riverant
MA
2023 F150 Lightning Lariat ER
Thanks. My FordPass doesn’t have that.
Farmford42
WA
69 Bronco
Farmer
I also got the mini 360 view after service for the sensor. Is the fix for that also something that aligns the 360 view ?
The Weatherman
Dean
South Central KY
It’s a five minute in and out of a specific program for calibrating the cameras. The tech likely didn’t read the cliff notes.
dsiegfried
Sieg
Portland, ME
Had a mobile tech come to the house last week to address some recall issues on my 2023 ER-XLT, which I purchased new 8 months ago (and still loving it!).
Repair Services:
RECALL2​
23B70 BATTERY MONITOR SENSOR REPLACEMENT​
24B56 INOPERATIVE FRONT PARKING SENSORS - SOFTWARE UPDATE IMAGE PROCESSING MODULE A​
RECALL1​
24P24 REPROGRAM THE FRONT HATCH CONTROL MODULE FHCM​
Took the tech about an hour. [edit] 360 camera view is unchanged, and the only thing I've noticed that is any different since the repair is that the lane-keeping feature comes on by default every time I start cruise control - but I suspect that's probably unrelated to the service.
Anyway, just wanted to report NO PROBLEMS or negative impacts (that I know of yet) from this recall work.
tommyb
Sonoma, CA
'23 F-150 Lightning Lariat
Repair Services:
RECALL2​
RECALL1​
I appreciate your update, good info. I tried scheduling mobile service for this, but my dealer would only do this at the shop in case the 24B56 update failed. So, I'm taking it in this Friday and I hope I won't have any issues either. I read elsewhere that one result of the 24B56 update is that lane keeping now automatically turns on when you turn on cruise control. A small bummer because I often use cruise control without going to the full Blue Cruise mode. Looks like now I'm going to have to make this a two button sequence to turn on Blue Cruise and then turn off lane keeping so I can just get the regular cruise control. I know, first world problem, but still. Anyway, glad to hear you had no issues. Crossing fingers...
NAVEWO
Tucson, Arizona
2023 Ford F150 Lightning Lariat ER Max Tow
Retired USAF Navigator/Electronic Warfare Officer
I've not had the CSP done but at some point the lane centering came on by default when enabling cruise control. My fix was to toggle off lane centering under Settings-Driver Assistance-Curise Control: Adaptive Cruise Control. Then when I want that feature on or to turn on blue cruise I just use the lane centering button on the left side of the steering wheel. Seems to work if you want to give that a try.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks Screenshot 2024-12-18 at 11.42.40 AM
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks Screenshot 2024-12-18 at 11.42.27 AM
I did this for a short while, it prevents full hands free BC from engaging when you hit the button. It will only do the basic, where it yells at you to wiggle the wheel every 30 seconds.
NAVEWO
Tucson, Arizona
Thanks...I guess I use BlueCruise so rarely that I was not tracking it would not engage fully without the toggle in settings. However, since I use cruise control all the time...and I'm not a fan of the automated lane centering when running around in town...I'd rather change the toggle on those rare times when I'm actually on a BlueCruise mapped highway.
LUXMAN
F150 Lightning PRO and XLT
Pilot
Repair Services:
RECALL2​
RECALL1​
Good to hear!. WE have been waiting to do this due to the problems that some have had with the Parking Sensor update. But our dealer keeps texting and calling us to get it done via Mobile. SO they are coming tomorrow, Friday Dec 20, to do both trucks! @TexasGardeningGirl said they have to do mine first and then if it doesn't get bricked, they can do hers. 😬
We are having the Parking Sensors, Front hatch and Charge Port updates done to both trucks.
Mike G
Mike G
N. AL, USA
Actually it's not even that.
It resets one bit in the asbuilt for the APIM to set the 360 camera view in the 15.5 inch screen so that it expands to fit the allocated space in the panel.
Sort of like in Windows when you want to change your desktop background image to stretch it to fill the entire screen instead of just the center.
It has nothing to do with the 360 camera alignment, which is a different tool that is essentially a training routine that enables the IPMA to "stitch" together the views from all the available cameras to provide the top-down 360 view you see.
dsiegfried
Sieg
Portland, ME
I checked the lane centering setting and it was already set to "off", so, hmmm... oh well, hitting the steering wheel button each time I turn on cruise ctl. is no big deal.
@LUXMAN - Good luck - hope it does fine for you!
LUXMAN
Pilot
Well The mobile tech came this morning. He was here for 2.5 hours and updated both trucks with the parking sensor update, the charge port update and turns out only one truck needed the frunk update. So all seems fine for now.
the charge port update .............
I mentioned you in the thread on this issue, folks are curious if it's still a thing that needs updating.
