2023 Mach E Fordpass Phone As Key Not Working Since Last Weekend Samsung Fold 6 Update
Stymied1978
Loren
Ford Mach E
Anyone else having this issue, called Ford and they said they would get back to me in a couple days, nothing. So you can install the phone as a key just fine, but after the install and it asks you to enter in passcode for the vehicle, about 20-30 seconds after the phone as key was authenticated it drops out and doesn't find the phone when trying to do the backup pass code, now my app just says "Phone as A key is trying to connect to your vehicle", you can start, stop, unlock, etc from the app but the phone as key doesn't work. This has to be a samsung update to the bluetooth security, since it works for the first couple seconds then stops. I have uninstalled everything, still doesn't work.
There was a recent Android update that is causing issues, yes.
Do you know if there has been a fix implemented?
By who? Ford didn't break it... And, if yours works, then it's fixed. If not, then it's not. I don't rely on PaaK, because it's not close to 100% reliable.
Stymied1978
Loren
Ford Mach E
It's for sure a Samsung update issue, just didn't know if anyone knew if they fixed it yet since I can't back the update up, won't let you.
Gimme_my_MME
Well so much for it not impacting Lightning
