inchman254
- First Name
- Dave
- Sep 16, 2024
- Collingwood, Ontario, Canada
- F150 Lightning Lariat, Kia Telluride
- Occupation
- Retired
For the cruise control speed sign recognition feature I would like to be able to set a percentage over the posted speed rather than a fixed number.
I normally drive between 15% and 20% over the speed limit. This works out to about 58 in a 50 and 95 in an 80 (these are kms, so ~35 in a 30 and ~60 in a 50 in mph). The problem is that the speed recognition feature only allows me to set a numeric speed additive, not a percentage. If I set 15 over, I'm now going too fast in a town and if I set 8, I'm going too slow on the highway. Being able to set something like 18% would be way better.
It doesn't really come in to play too much on controlled access highways because, if set for highways, the offset will normally be fine.
The other problem is that if the feature is turned on and I have adjusted the speed from the offset value, every time I pass a speed sign, even if it is the same as the last one, it reads the sign again and reapplies the offset, overriding my manual selection. My Telluride doesn't have %'age either, but at least it recognizes that the signed speed hasn't changed and won't change speed if I have manually adjusted it. It does quietly offer to return to auto offset, though, every time I pass a sign.
This probably applies to more Ford vehicles than just the Lightning.
