Pitbull2o08
San Diego
2011 F150 FX4 Ecoboost
i got 1.4. But i'm missing 2 TPMS values.
Jmendozanunez
Jorge
24 Ford lightning
What am I doing wrong to connect my mongoose to fdrs and forscan . Says unable to connect ...Installed drivers and I'm able to get fdrs to says connected shows battery volt but when I try to scan Vin says device not connected but when I enter vin manually i click connect bottom symbol says connected ?
Pitbull2o08
San Diego
Mike G
N. AL, USA
Did you install the VCI manager from the Ford site as well?
Jmendozanunez
Jorge
24 Ford lightning
Yes I did . After installed that one I got vcm device options...I also can see my driver's are installed shows vehicle pass through and shows mongoose....but just strange I cannot even get forscan to connect
Is this a known working Mongoose? I haven’t looked but I think the Mongoose driver includes some toolbox programs you could try.
Does the Mongoose blink green when you plug it into the OBD port?
Mike G
N. AL, USA
I'm not sure what to tell you, I've used my Mongoose with FORSCAN plenty of times, but I generally only use the OBDLink MX+ for that (different laptop).
Jmendozanunez
Jorge
24 Ford lightning
Yes blinks green then solid green. But no communication still
21st Century Truck
Martin
I seem to remember that the Mongoose firmware can be flashed with upgraded more current RAM software... might be worth a look at the manufacturer's website. Not that I've ever done it on the Mongoose... I have done it with other dongle equipment.
Good Luck!
Pitbull2o08
San Diego
This video and @mr.Magoo helped with with issues setting up
PJnc284
Garner, NC
Sure you ordered the Ford version of the Mongoose? Where are you located? Maybe someone near you has a working one you can try. The only thing I recall installing was the Opus IVS Driver and for FORScan I just selected the mongoose on the screen below
Ford F-150 Lightning ECU module programming guide using FDRS 1737738963780-7s
