Truck and Ford Charger not communicating properly
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
My truck had a 12V battery issue and it was replaced. During the problem but now after replacement the truck and charger aren't communicating properly. Oh yeah, and at the same time I changed my wifi from an Orbi Wifi 6 mesh setup to a Deco Wifi 7 mesh system. During this time, the home location doesn't show up in the Ford app, the truck doesn't automatically heat up before leaving for work and when I plug it in it charges to 100%. I've looked at the setup and changed the wireless, but still the same thing. Should I just reset the charger - an option in the charger app and then reconnect it? Or is there another simpler solution.
Ford F-150 Lightning Truck and Ford Charger not communicating properly IMG_4908
Ford F-150 Lightning Truck and Ford Charger not communicating properly IMG_4904
The wifi connection doesn't play a roll in change limits and preconditioning.
Go into your charge locations in the truck and delete your home location and set it up again. I would also delete your preconditioning schedule and redo that as well.
And I would do that in the truck, not in FordPass.
sdingeldein
Steve
Burlington, NC
Ford F150 Lightning
Physician
Thank you!!!! I will give it a try.
Edit: the home location, in all the 12v issues and work done "clearing out" the electrical software,, had been deleted. I had tried to add it in the app before - no go - but in the truck it added just fine. I deleted all the preconditioning times and added them back in. Thanks. You folk saved me a LOT of time and frustration.
The charge station issues are related to your home network, I'd do a master reset of the FCSP from within the cabinet.
htobin
Howard
Ovalo TX
A humble plea for many of us less sophisticated viewers. When using abbreviations, please consider spelling out what they are in the initial post. Many of us are simply unfamiliar of the less common abbreviations. Thanks.
MaintGrl
Marsha
El Sobrante, Ca
I love it when a plan comes together . . . Colonel John "Hannibal" Smith
FCSP (Ford Charge Station Pro)
Master reset button is on the circuit board:
Ford F-150 Lightning Truck and Ford Charger not communicating properly reset button Ford CSP insides 1
BTW, when setting up the FCSP wifi with your home network, the 2.4GHz signal from your home wifi is preferred - travels farther and through more things like walls. So have your smart device connected to the home 2.4GHz wifi through settings on your device, then start FordPass then start the FCSP setup app. The setup app will search for the FCSP - it can sometimes take a while and a few tries. When found you enter the login and password that came with the FCSP (a sticker on the manual has the info).
The FCSP is sometimes finicky - I had to hard rest with the red button mine a few times before I could get it set up - although I never actually completed the setup - it would not add the FCSP to FordPass - but the FCSP charges my truck fine anyway - I do all my charge time and settings with the truck.
PS: that image is from an install video ( I think ) and you'll note the AC power lines are not installed. They would be attached to the terminals on the circuit board near the bottom left - and coming in contact with the AC power could be a deadly mistake. USE CAUTION when the case is open and the power is on!
