GoHawks
2022 Lariat Lightning ER
I happened to have my truck in today for something else and this popped up a day or two ago on my app. I had them apply this software update. It took multiple hours, killed the original 12V battery, the dealership replaced the 12v under warranty, drained the new 12v, recharged the new 12v and kept it on a battery tender to get the update complete. Just passing along my experience. I had not had any issues related to this prior that I was aware of. My 12V was less than 2 years old.
I scheduled mobile service to come fix my camera screen size this week because it was the ‘small’ size and do a recall on the front trunk latch. I also had an issue with ‘my key’ not being configurable because of a software glitch. Long story short, when the tech was updating the camera configuration, he noticed the other modules were not really updated. He had to get approval from the service manager to reapply this CSP. He apologized for the previous tech and spent all day at my house applying this update, doing the recall, and spent hours on the phone with Ford diagnosing the glitch with ‘mykey’ which required updating multiple modules. This CSP and the recall work are complete and accurate including camera configuration. I can also configure ‘mykey’ controls but still have some buggy software issues (now documented with Ford). Bonus - walk away locks were enabled during the process. I still can’t figure out when this feature activates - it seems only in public locations, not my driveway.
If you are experiencing the camera issue, I would get verification they did everything else correctly. My first experience was a new 12volt battery and failed CSP configuration. Very poor service which was only redeemed by the mobile tech being completely honest and investing the time.
Mike G
Mike G
N. AL, USA
If a dealer 'Mobile' tech arrives at your location to perform any updates on your Lightning and you don't see a battery charger/powersupply being connected up before they start, you need to ask questions.
The tech may be assuming that like the ICE and Powerboost hybrids that have larger capacity 12V batteries that they can get away without using a powersupply like the instructions say. But not on a Lightning with a 36Ah 12V battery.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks IPMA_Powersupply_required
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
Cursed with the small 360 cam now
I'm not sure if i have the small 360 view display. Can you guys look at this snapshot and determine if i have the small display? This 360 pic isn't much wider than the volume knob, but i can't remember how the display normally looks.
Thanks.
Ford F-150 Lightning CSP 24B56 - Inoperative Front Parking Sensor(s) - IPMA Software Update for Certain 2022-24 F-150 Lightning Trucks 20250308_132119
PJnc284
Garner, NC
Thanks.
Yours is normal. The only issue is on 22's where the dealer didn't follow directions so they're left with the black box around the image until it's either fixed in FDRS or FORScan.
Lightning Rod
North Coast
Ahh... ok. I thought for sure that the 360 was bigger than that.
In fact, it doesn't look any bigger than @MichaelCA "s post that I quoted. :unsure:
PJnc284
Garner, NC
It was bigger but the update also changed the size and how the menu on the left was displayed so we're stuck with it. Maybe enough people will complain to Ford and they'll revert back to the previous since within the next decade.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Just had my front sensor CSP done on Monday. And the dealer apparently did not hook up a power supply to my 12v. Luckily I came in with 100% 12v charge. But when I picked it up it was very low. I was getting low battery warnings on the center screen, etc. after driving a couple days everything was back to normal. As for the front sensor update; I didn’t really notice any difference in the sensors kicking in as I pulled up close to my garage door. It still only starts beeping when I’m extremely close, which is kind of dumb in my opinion. My other vehicle (Toyota Highlander) starts the initial beeping like 4 ft away. However, I did notice that bluecruise is better able to to detect suddenly stopped traffic on the highway and brake sooner than it used to. So that’s a plus.
