DC Fast Charging lack of info
BSull
Robert
Mesa, AZ
Corvette, F150 Lighnting, Mercedes GLC300
I'm not a road tripper, but I like to be ready for stuff, you know, just in case. So I just had to try DC fast charging. My first DC fast charging session was at a EA charging station located in Globe AZ. Fairly small only 3 or 4 plugs but I was the only one using the facility so it didn't matter. Followed the directions on the charger screen and everything worked great. I only added about 7.9 kWh since this was just a test for me and I had enough charge to get home. The truck didn't tell me squat about what was happening, the charger was my only information source. But hey, I got a notification in FordPass after the fact that my charging bundle had been reduced by 7.9 kWh.
Then I received my A2Z adapter the other day and decided to try a local (20 miles away) v3 supercharger. CarPlay navigated me to the charging location because Ford nav had no clue a useable charger was located there. Got to the location and attached the adapter. Hardest thing about that was locking the adapter and the charging handle together. Tesla app wanted my billing address updated for some reason, I had added that the other day, so gave up on that app at least for that session. FordPass was useless since it didn't show a charger anyway, so I tried plug and charge, it worked. I left the truck on since I wanted the A/C to work the truck showed Fast Charging in orange on the big screen, no other indication I was charging, how fast I was charging etc. However, SOC was updating and I had set a 60% charge limit that appeared to work. In the end, FordPass had a notification that I had been charged $6.88 for the session.
Lack of real time information in my truck especially when using plug and charge is pretty awful. Just my $.02 as a newb to this DC thing.
potato
BC, Canada
2023 F150 Lightning XLT ER
Yep. Not even showing the charge rate in kW anywhere is a huge WTF from me too. You can get that with an OBD dongle, but it's pretty annoying Ford's philosophy is to hide any and all technical info. Wouldn't want to confuse Grandpa I guess.
FordPass and Tesla app...
BSull
Robert
Mesa, AZ
While I agree that the truck should give you the charging rate, I will point out that you can get the info in the Ford Pass App. You don't have to have an OBD dongle.
Umm, nope tried opening FordPass 5.0, it had no clue I was DC Fast charging.
BSull
Robert
Mesa, AZ
The Tesla app shows real time charging status if you use that to start the charging.
Yeah, if you use the app to start the charging. I did not use Tesla app, it wanted me to update info that I'd already updated.
Make sure you're looking at the [Energy] tab.
BSull
Robert
Mesa, AZ
Yeah, I was. Even in the charge history the latest entry is 25 May at home.
Public charging only shows the map, not sessions I've completed.
I always see current charge session info on the energy tab while charging. Current KW rate and estimated finish time.
I’ve also had charging sessions randomly not get logged in history.
Ford's back end is a big part of this issue, sometimes I get the record a few minutes after unplugging and other times it took 12-24 hours to show up, mostly in version 4.x
It looks like the 2024’s will have this and hopefully we will get it also.
  • Updated charging speed display on the instrument cluster so that customers can see charge status and speed of charge instantly, including an estimated finished charge time
Agreed. Sometimes, the log entry is almost immediate, sometimes it never shows up. Often it’s something in between.
Chriseberle
F150 Lightning SR Tesla Model X
Part of buying a Ford or any other non Tesla is you are tied to 3rd party charging systems. I have travel thousands of miles with my Lightning and have 10 separate apps on my phone for that reason. Electrify America has one redeeming quality and that is the machines and the app show charging speed. That is not necessary the same as what the truck is taking because of heat loss but a good estimate. As for Tesla charging you must remember that Ford is the first to have use of the Tesla chargers and therefore it takes time for the software side of things to become seamless. The Ford app has been great for showing charging speed at Fast Charging Stations and really not sure why the truck does not show charging speed. No doubt it is a complaint of most owners.
invertedspear
AZ, USA
lightningcalcs.pages.dev
Ford Engineer: And here's the display of the charging speed
Marketing: Why is it so slow?
Engineer: Well after 80% the process slows down for technical reasons and after 90% it slows to a crawl for more technical reasons
Marketing: We can't have people taking screen shots of that, no one will buy such a slow charging vehicle
Management: Remove that feature!
