Skier167
Instrument cluster looks good. No DTC’s in IPC. only DTC I have is U2101 in the IPMA which I’m figuring is related to my pre-collision assist error on the cluster screen.Before you do that, start up your truck and check to see if your instrument cluster comes up normally. If all looks good, shut back down and go into FDRS and do a new network scan. See if you have any DTCs. If all you’re getting is U2100–Failure to configure, try a PMI selecting new module and see if that clears you up. Then do another network scan and see if the IPC update is still there.
