Heated steering wheel barely gets warm
sen7inel
NJ
Lightning XLT ER, Model Y
As the title says, the heated steering wheel barely feels warm to touch, as in I can barely tell it's on in some spots, completely cold in others. Has anyone else experienced this?
EDIT: solution in post 16
MrLoganRoss
Logan
Seattle Washington
From 10 o’clock to two o’clock are the warmest, but the wheel is so big that most people, including me hold it at 9 and 3. There is a way to change the target temp with FORScan. There is a recent discussion on this.
sen7inel
NJ
Thanks for this, yes it seems 10 to 2 is the warmest. Best temp I got around there was 89F after about 3 minutes, then it tapered off to 85-87.
FloridaMan655321
1973 F100, 2024 Flash
First vehicle I’ve owned that has heated steering wheel and I am kind of liking it. I am not in the tundra, so maybe my expectations are low.
Has your truck received a recent update that might have caused this issue?
sen7inel
NJ
Tough to say, I haven't really tried the heated steering wheel function it before the extra cold weather in the north east last week. You can tell it's working, but unlike our other car not enough to appreciably warm the hands on a cold day. Maybe FORScan is the answer, too bad you can no longer buy a license.
Oafy44
Georgia
23 ford lightning
Landscape contractor
I love a heated steering wheel even during summer. Both my lightning and f350 (both 23’s) are the same low heat . Fords used to have great heated steering wheels about 3 years ago
my wife’s Range Rover will melt your hands off. It’s amazing
potato
BC, Canada
2023 F150 Lightning XLT ER
For me it always starts off pretty toasty then backs off after 10 or 15 minutes. It would be nice if it didn't back off as much as it does. As you say, it's barely detectable after a while.
I <3 My Lightning
XLT ER
I agree that it is not hot enough.
Now this would be a great OTA to add a setting to everyone's infotainment system... You can adjust on screen when you tap the HVAC shortcut for driver only heat/on/off
Low, medium and high would suffice, where low is the current level and high is at the top and of course medium is between the two.
Ford F-150 Lightning Heated steering wheel barely gets warm 1719244061659-ul
G-Zeus
Garth
Massachusetts
22-F150 Lightning Lariat SR
I went into Forscan and jacked it up to the max. Toasty.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
I just point my vent to the right of the steering wheel at it when it cools off after 15 minutes. Problem solved
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
Mine also starts toasty on Pre-departure heating, then drops off... I wonder if it is tied to the cabin temp setting - I keep mine at 65. Something to experiment with next time I go for a short trip.
I agree, there should be a steering wheel temp setting you can change.
sen7inel
NJ
Any obd2 to usb adapters recommended in particular? I was looking at an ELM327 with an MS/HS switch, assuming this will get the job done?
