Whammy Bar
Place your bets on the over under date when this gets resolved.@Ford Motor Company we've got a problem.
I'll start the bidding at ... November 2025
It's not that, it's making sure that there is not an active 400v service line outside the vehicle if it's not needed.The toggle on the screen says to keep the outlets power often truck is off . I have the option of setting how far down I am willing to let the battery drain before the vehicle turns off. That is how the on board power system should work . Simple
I absolutely agree with Karlo. I have my truck set to turn off the outlet when range hits 70 milesThe toggle on the screen says to keep the outlets power often truck is off . I have the option of setting how far down I am willing to let the battery drain before the vehicle turns off. That is how the on board power system should work . Simple
Yes Floridaman, and this is a option that started with the 2024 modelAfter reading all of the posts, I wanted to mention that I always turn my truck on when I have the bed power enabled. I also go many many minutes without any usage during a brew day, and I don't have any issues with the power cutting off. So I take it from all the posts that this is an issue with when the truck is off and the bed power is enabled?
So maybe this option is really only useful if you're powering your house via the 240v.Yes Floridaman, and this is a option that started with the 2024 model
I believe the default is based on a percentage of battery left. It translates to miles, but it actually percent of battery life.The main shut down timer appears to be set at 30 minutes and will turn off the truck if you inadvertently leave it on. I did disable that anyway , even though it is shutting down in 6 minutes. There is another protection that shuts the outlets off at an amount of predicted mileage that I can adjust according to how near a charger I might be. The default is 102mi (weird). I have it set at 50
I think this is part of the misconception here and Ford is doing themselves no favors. There really isn't much difference between the truck being "On" and the truck being in "Truck Off; PPOB Mode On".If I stop to get something to eat I would like to not have to leave the truck powered on just to keep the cooler outlet alive.
I’ll see you that and raise to: Sooon after BC 1.4 rolls out to 2022 MY.Place your bets on the over under date when this gets resolved.
