Way to keep front camera view while driving?
tsallen
Tim
Arizona
2024 Lightning Flash
Is there a Forscan setting that can allow for the front camera to be viewable while driving at speed?
For reference, I have a 2024 Flash model.
Not that I have seen. The two front views and the 360 disappear when in Drive.
But I'm not sure it would be useful. Might even be a govt. regulation.
potato
BC, Canada
2023 F150 Lightning XLT ER
It would sure be useful if it would stay at least while at parking lot speeds. Trying to maneuver into a tight spot it's sure annoying having to turn the cameras back on every time you shift gears.
Riverant
MA
FORSCAN lets you. It even turns on off road views. Confusingly it defaults to being in everytime you put the vehicle into drive, but it’s there…
Ford F-150 Lightning Way to keep front camera view while driving? IMG_3607
Louie7300
Louie
Louisville, KY
2023 Ford Lightning ER Lariat
Small business owner
What do you change in Forscan to allow this? As stated before, this would be great for parking in certain situations.
You said “in” but did you mean to say it defaults to ”on” every time you put in drive? So the cams stay on after you shift to drive?
Did you enable rock-crawl mode in FORScan?
Lytning
Georgia
Once I begin to turn in to a parking spot, I touch the camera icon at the top of the screen. The camera turns on, and I use it to center the truck in the parking spot. I have not made changes in Forscan.
Riverant
MA
Yes I meant on, thanks.
I enabled both cameras at speed and off-road front cameras at speed. If I remember, cameras at speed didn’t work until I enabled the off road option. I do like the tire tracks..has been helpful parking and entering the car wash track. Defaulting to on is a smallish annoyance.
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
Related - I just want to disable ALL auto camera swapping. When positioning a trailer, please just leave the camera set how I set it. Changing the camera every time the gear is changed is SUPER inconvenient.
MountainAlive
Massachusetts, USA
I really think the front camera should come on when you go under say, 5mph or are just getting going from a stop. A standing child can be eclipsed by the front of this truck. It’s no different to me than when the rear camera comes on when reversing. Same idea.
There is a rear camera delay setting in Sync that keeps the rear camera on until you reach a certain speed threshold after going from Reverse to Park. I find this satisfies most of my trailer positioning needs.
@Louie7300 - same here as Lytning. The front cams and 360 view can be enabled as long as you are going 5 mph or less.
Gerstein1989
Alexander
Barrie, Ontario
2024 Lightning Lariat
Plumber
what forscan changes did you have to make for off road cameras at speed ?
dmd3home
Central Coast CA
Lightning, Spark EV, Tesla Y, BMW X5 phev
EXACTLY!!!
Gerstein1989
Alexander
Barrie, Ontario
Plumber
EXACTLY!!!
This would be great. Gm already has this on their trucks. When you switch from reverse to drive the front camera goes on then turns off once you reach a certain speed and if it detects a pedestrian near the front it will turn on front camera. Ford decides what we need not us lol. Maybe one day they will actually listen.
