Wireless CarPlay intermittently has no sound
Mmiketa
Virginia, USA
'23 Lightning Lariat ER
I've been having it happen more often. I typically just toggle carplay on/off in the car's menu.
MM in SouthTX
2022 Lightning Lariat ER
This happens to me occasionally. One thing you can try when you have no audio on a call is hitting the Audio button on your iPhone. A list of speaker sources pops up:
iPhone
Speaker
CarPlay (or something like that--not looking at it right now)
When I can't hear someone on a call I find that it is set to iPhone. Choose CarPlay.
That has corrected the problem it for me when it happens. There's also a way to access the output source while trying to play music but I'm not sure what the steps are. Basically, the iPhone is not putting out to CarPlay, but instead to its tiny speaker that you listen to when it is up to your ear. Change that and you fix the problem.
Not sure how to keep if from happening, but this is a fix that might work for you.
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
It used to be only occasionally for me but since the Tesla update and the last few iOS updates it’s been pretty much every other time I drive the truck. Sometimes the fix is to switch audio apps in CarPlay. For instance, if it’s Spotify that’s giving no audio, I’ll switch to Apple Music or Sirius and that’ll kick it in. Most of the time however I have to reboot the Sync system (steering wheel- hold volume down and track up until it reboot). Usually works every time Just keep it in mind that you’ve turned the volume all the way to zero in the process.
adoublee
Midwest
2 EVs
This happens to me regularly (more regularly recently) and it is the biggest pain point with the vehicle - and a big pain point. CarPlay will be connected and running but no audio coming through. I do a reset with the bottom left and bottom right buttons on the steering wheel once or twice and it usually comes back, but this takes as while for the reboot. AND one of the two buttons is volume down and it ALWAYS takes the volume down to zero. So I have to up the volume after the reboot to even know if it worked.
Stang68
NJ
Mach E GT Performance, Lightning Lariat Extended
We’re seeing this in our Lightning, too. Either it’s an iOS issue or a recent Sync update broke something.
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
I have found the easiest way to fix is toggle wi-if off/on on my iphone.
Daragh
North Carolina
2023 Lightning Lariat ER
Mine does this every so often too, don't believe its a phone issue as my wife's car never has this issue with my phone via wireless CarPlay.
Anyhow quickest fix I found was toggle the wifi On (disconnects CarPlay) tun bluetooth off then on, disconnects from truck. then select your phone on sync and select CarPlay. The reconnect has so far fixed the auto issue for me everytime. I have not had to reset my phone.
I got very tired of the issue, CarPlay just connecting a portion of the time. I disconnected it, reconnected and chose wired only. It's only a slight pain to plug the phone in each time, but it has relieved the stress of me cussing most every time I drive the truck.
There are a couple of benefits. The phone charges without having to dig down to the worthless charging pad and I get what I believe to be better quality music. I've invested in a sound system upgrade and I pay services with higher bit rate music, so might as well plug in to take advantage of it. My less frustration overall.
JohnnyEV
CA
It's not just carplay. I use Android auto and it's happened twice in the last two weeks.
RedLightning86
Wisconsin Dells
Seems like it happened after one of the last updates, to me. Of course iOS updated, too, so could be the combination was jinxed. Ford will fix it
proprepper
Grayslake, Il
2022 Pro SR
done with work!
Yup, Android Auto does the same thing. It will be working perfectly then it finishes a track from any music app then the next track plays and no audio. Pause then play... nothing... pause then play again, sometimes that works sometimes not.
MSanders
Michael
Iliinois
F150 Lightning
This has been an ongoing problem for me as well. Still not fixed.
I also toggle CarPlay on and off to fix it, but it's such a pain. I'm considering going with the "wired only connection" solution for now.
I'm a much happier person since I removed "wireless" car play from my life. I plug in every time and it's almost flawless. Wireless just isn't ready for prime time.
Drillerr
Darin
Utah
2019 Ram Limited
I’ve done the same. I reconfigured Sync to totally eliminate wireless. I usually plug in anyway to charge. Much less stress.
Reactions: GDN
