Ajzride
thanks for the tip, it didn’t do squat for me though. Still at u2100 on the IPC and still at 21281.244 on sync with no APIM updates available.Just to be clear, the configuration in FDRS, below -- IPC - Instrument Panel Cluster (IPC) Configuration. I ran that successfully and that cleared the DTC. The self-test confirmed everything was good.
I did not use Forscan to clear the DTC in my IPC.
