Slated by whom? I miss that announcement.It is already slated to be added to a future software update. Just unsure of timing
If it is a Home Flex, the settings are in the Chargepoint app. You can dial it back to 20 A breaker, 16 A charging. Just posting a link to show what it looks like. They made a couple other Level 2s that weren't adjustable.I have an existing level 2 charger- charge point.
Here is what I own.If it is a Home Flex, the settings are in the Chargepoint app. You can dial it back to 20 A breaker, 16 A charging. Just posting a link to show what it looks like. They made a couple other Level 2s that weren't adjustable.
https://www.bulbs.com/product/CPH50-NEMA14-50-L23
Look again, or read the manual. But yours is locked to some rate right now, so no issue.Here is what I own.
https://www.amazon.com/gp/product/B07WXZDHGV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I looked through my app and don't see a way to adjust.
That's the one. The Flex in the name derives from its flexible charging settings in software. The Home Flex has to be 'activated' to have the setting available. To change the setting, you may have to re-activate the charger to see it. It defaults to 16A output. There are FAQs about the process under Settings->Help->ChargePoint Home->ChargePoint Home Flex (iOS)Here is what I own.
Wow.That's the one. The Flex in the name derives from its flexible charging settings in software. The Home Flex has to be 'activated' to have the setting available. To change the setting, you may have to re-activate the charger to see it. It defaults to 16A output. There are FAQs about the process under Settings->Help ->ChargePoint Home Flex (iOS)
It's structured to complicate the process so that it is not easy to increase the amperage once set.
