BennyTheBeaver
Defaulting to last used drive mode is a straight forward setting that should be implemented. Needing to reconfigure your truck at every startup (unless you remember to hit ok on the steering wheel within 5 seconds of turning on the truck) is a PIA.This is really not needed and better to default to normal. Sport mode will reduce range too.
If I want to reduce range in Sport mode, that is my choice. I pay $0.07/kW, I'm not concerned (currently) about hypermiling or squeezing every last inch out of my range. I want to enjoy my drive/ride. If I'm roadtripping or wanting to conserve range, I have the option to change it.
