ZSC100
No all configuration changes are done in the As-Built area like other configuration stuff. Execute the changes the same way and you should be able to get the handle working and responding to the capacitive buttons PIDs. Where you have custom selected there should be a drop down for available. But as of just last week it was not there yet. This means you will need need the files. I will send to you in a PM.Ok, now I'm confused on the firmware update. Am I supposed to put those values into a file for the system to write? Also, I don't appear to have some of the sections that you had values for, is that an issue or do those values overwrite?
