Has Anyone Had Ford Dealer Install Walk Away Lock (WAL) by Installing BCM Update Through FDRS? If so, how and was there a cost?
flypony53
Rodney
Houston, TX
One thing that might work is if you have an open CSP for a software update on another module you could ask the tech for a favor since they’re already doing FDRS updates. You might get it for free, or you might get charged a small labor charge. I think they even do this with mobile service.
This is the route I took. I had the BCM CSP, but I also was having an issue with my AC running on Auto setting. The blower was not functioning correctly. They used that as a reason to actually update all of the modules in my truck. They said it took a while, but all of them were done. I have walk away lock now, but wish I could disable at the house.
rugedraw
Javier
Miami
Auto Sales
You can add the toggle to turn WAL on and off with FORScan.
Ford F-150 Lightning Has Anyone Had Ford Dealer Install Walk Away Lock (WAL) by Installing BCM Update Through FDRS? If so, how and was there a cost? 1729009399220-d4
rugedraw
Javier
Miami
Auto Sales
What software revision on the BCM do you need to make this work? This is mine.
I believe it's AAM, but I'm going off memory that is not my best asset.
rugedraw
Javier
Miami
Auto Sales
and you assign that by location?
If you have a zero in that location, change it to an 8. If you have a 1, then change it to a 9 and so on.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
I got WAL with CSP 24P56. It came out of the dealer with it active. There is no switch to turn it on or off in the settings like my wife's MME, but it works.
Oh boy. I don't actually want WAL. I leave my truck unlocked in the garage. I hope Ford comes out with an update so you get WAL and the switch together.
Adventureboy
My understanding from the team on the forum is if you get the latest APIM update, the switch is there. Alternatively the switch can be activated using Forscan.
ziptbm
'22 MME GT & '22 F150 Lightning Lariat ER
Well...after two weeks of phone tag with the Service Team at Serra Ford, I was told today their Ford FSE's have instructed them NOT to install the BCM on my vehicle because it's "not supported." So, since their FSE advised against this, they are unwilling to install this update for me regardless of my willingness to pay for the time required.
Just add this to growing list of strikes against Ford....from the horribly managed OTA update process, required equipment to manage FDRS updates myself, locking data away behind broken APIs for 3rd party integrations, and poorly designed features (e.g. open frunk turns off remote start, WalkAwayLock, multi-car issues, etc.), clearly Ford is in way over their heads with EVs. This will be my last Ford.
So, in the meantime....I'll be contacting other dealers....anyone have any other suggestions?
PJnc284
Garner, NC
Mine updated the BCM for free yesterday but the truck was in for service to install a new battery sensor. Would make sense for them not to install though since there's no way to disable WAL at the present time without enabling the button in FORScan. I'm sure you could find one if willing to pay though. My sheet has it listed as .3 hrs but it's more like 5min from posts I've seen. Would also be nice if there was a timer. If I'm using PAAK, I barely have enough time to walk around to the passenger side before it locks. If just using the Fob, it's about a 20 second delay.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), F150 L
I asked the dealer about this, they said they will see if the BCM is scheduled for my truck. But they won't do FORScan, they say that's aftermarket. So if they do the BCM I won't have the slider.
No dealer uses FORScan.
Mike G
N. AL, USA
that’s exactly why I called to ask. They just don’t know anything about this special login requirement.
They’re not aware of it because it doesn’t apply to dealer techs. Dealer techs are granted permissions in the FMC dealer system to be able to do PATS functions. They don’t need a NASTF login. That’s just for independent shops like locksmiths.
ziptbm
Lesson learned. Do NOT mention the NASTF login requirement when asking your Ford dealership to install this BCM update as that's likely to confuse the SAs/Techs and waste time.
To recap for those late to the party:
1. Verify the BCM update is available for your vehicle through FDRS.
2. When scheduling your next service appointment, ask specifically to get it installed as well. Pro Tip - be sure to ask for a tech or service advisor that can dig into these details of your vehicle....
3. Be persistent.
4. Come back here to get the Forscan values to enable it in the UI. It's mentioned in this thread, but this this post does a good job explicitly saying what needs to be changed.
Thanks everyone!
Good luck.
