Extended range battery pack is 131kWh usable, no?ER is 141kWh
True, but we have ~10% ac to dc conversion losses to factor in.Extended range battery pack is 131kWh usable, no?
There's another 10% charging loss to factor in addition to what I had in my table?True, but we have ~10% ac to dc conversion losses to factor in.
131/.9*.65/9.6 = 9.85 hours
More hours?What are people's experiences charging the Lightning ER on a L2 Charger limited to 50A circuit?
How many more hours to go from 15% TO 80/100%
Thanks,
Nothing more than the 10% your chart accounts for, I just wanted to represent the USABLE value pack capacity and determine the hours it takes at 240 x 40 real amps to regain 65% usage.There's another 10% charging loss to factor in addition to what I had in my table?
I just did a similar charge last night. I arrived at home with 20% and charged overnight to 85% . According to Ford Pass app, energy added was 85.3 kWh. It took exactly 7 hs and 40 minutes, but that was on a 48 amp output charge.What are people's experiences charging the Lightning ER on a L2 Charger limited to 50A circuit?
Thanks,
Ford recommends only charging to 90% unless going on a long trip.Extended range battery pack is 131kWh usable, no?
If I have a 50 amp circuit breaker. Could I simply replace it with a 60 amp to get the usable 48amp charge rate from my charger?More hours?
40 x 240 x 90% (10%) loss = 8.64kW.
That's what you need to know. Per hour, that's what the truck will get. Simple math to look at your SOC.
15 to 80%? 65% x 131 / 8.64 = 9.86 hours.
15 to 100%? Either redo the math, or do 20% x 131 / 8.64 = 3.03 additional hours.
Note - you should be charging to 90% daily, not 100%, not 80% (see manual). 100% is for trips, where the range is needed.
If the circuit isn't installed, consider a 60amp circuit with a 48amp charger. How much faster will that be? 48/40 = 20%.
Why not just change the amperage output?How I figure it:
I would ensure you can recharge your daily driving needs within the cheapest time of use your utility provider has.
I'm in San Diego where my cheapest charge period is midnight to 6a. This provides me 6 hours to charge each day. If I'm driving no more than 60 miles each day, I need a charge rate of at least 10 miles/hour (60/6). By my math above with the Lightning, that means I should use at least a 30 amp circuit.
For that reason and versatility, I intend to replace my 100a Ford Charge Station Pro with a 60a Tesla Universal Wall Connector.
Probably not. Both the EVSE and the branch circuit wiring would need to be capable of 48/60A, respectively. The connection would also need to be hard-wired if it isn’t already.If I have a 50 amp circuit breaker. Could I simply replace it with a 60 amp to get the usable 48amp charge rate from my charger?
Why do any of that? It can be changed from within the app but also the truck can just be limited to a couple hour charging window. There's no benefit to slowing the charging down to take up the entire 6 hour low rate TOU and seems like it would just introduce additional, unnecessary charging overhead.Why not just change the amperage output?
