Newton
I would ask permission and use a restricted charging level. There are different qualities of outlets, If the outlet is not designed for EVs (like most of them) then you could be risking a fire. I think the AirBNB owner would be rightly upset if they came home to a melted 50A outlet.
On the other hand, one place that I stayed out very kindly ran a 120V "extension cord" under the locked garage for me. Man, was I nervous but I set my car (Kia) to its lowest level overnight and only raised during the day when I could feel the cord. It did start to get warm. It gave me enough range to make it home, though.
I do agree that it should be a more prominent discussion, my Mom was incredibly surprised that I charged the Kia using her garage outlet (without an extension cord.) It might make more sense for a car that gets 4+ miles/KW than one that gets 2.
I do think that the time to charge to "full" or "80 percent" needs to be de-emphasied a bit. Miles per hour is a better metric. If you are 20 miles away from a DCFC, then you need ... 20 miles added to your battery. On the Kia (my more efficient, faster charging car) I tell people that it takes about 18 minutes to go from %20 to %80 and they look blank -- I should tell them that the few times that I use a DCFC I am not charging to %80 unless I need to hit the facilities in the Wall*Mart. I just want enough to get home, no sense paying high prices for electricity that I don't need. Adding 60 miles takes less time than navigating through the parking lot to get to the charger.
