Update 6.8 update problem
Etsquared
ET
Orlando
F150 lightning
Was having the same problem for two weeks. I tried charging to 100% after charging 90% for several months. The 6.8 update went right through to completion. Don't know if that was a coincidence.
I did the same thing. Coincidentally I believe the $10 a month to Ford Connect was helps those downloads and updates process seamlessly and securely or I am just rationalizing $120 a year
invertedspear
AZ, USA
lightningcalcs.pages.dev
Rationalizing. The truck connects to Ford without Ford Connect making the hotspot available to you. It uses the same cellular modem. The remote start and lock/unlock in the app depend on it.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
The BMS recall fixes the issue. There's a less than zero chance that even if you manually charge the LVB to the top, the update will still fail because the module is not reporting the charge level correctly.
sicamoose
Simon
Vernon, BC
2022 Ford Lightning
Self employed
I have been trying to update mine for several weeks now. Newbie here - what does LVB stand for?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Low Voltage Battery. It’s the small 12V battery behind the door at the back of the frunk, just like the battery on a gas vehicle.
sicamoose
Simon
Vernon, BC
2022 Ford Lightning
Self employed
cool, thanks! I too am affected by this issue...so, from reading some forum threads, it seems, MAYBE, if I charge my 12v battery, it may help with this update? I have had a few low voltage warnings this winter...
carys98
Cary
Raleigh, NC
2021 Ford F150 Platinum FX4 EcoBoost
Yes, it is imperative for the LVB to be charged up for this type of update. By "this type", I mean an update that requires the vehicle to be parked and inhibited while it installs.
sicamoose
Simon
Vernon, BC
2022 Ford Lightning
Self employed
So, got in the truck this morning and noticed all the saved radio station presets were changed! And you know what that means! Update successful, and I did nothing different (ie charging the 12v battery, etc). Kinda spooky... The day after I post here, it works!?
Tommy Holt
Tommy
Austin, Texas
2023 Lightning ER Lariat
Many tries, many fails. Took mine to the dealer this morning to fix and update. I’ve already had all the aforementioned updates. Fingers crossed.
2sleep
Bob
Western NC
23 Lightning Lariat Antimatter Blue, 2008 Prius
Is there a way to see all the updates that have actually gone through to completion verses those that have been attempted?
No
2sleep
Bob
Western NC
shame, I kinda thought that would be the case.
PTS will show OTA history, but I would need your VIN to get it for you. You can PM me if your prefer to not post it publicly.
