Are our doors “manual”?
Dinozero
Kentucky
2023 F150 Lightning ER Lariat
Something that always scared me about my Tesla when I had it is the electronic locking doors. I’m not sure but the Mach E may have something like that too.
I’ve tried researching this on our trucks and can find the specific answer. Since our trucks are so similar to a gas, F150, I would assume they are manual. But wanted to ask.
This story made me think of it
https://www.theverge.com/2024/6/21/24183439/tesla-model-y-arizona-toddler-trapped-rescued
Edit: thanks everyone: makes me love our trucks even more
The lever systems are mechanical, locks are electrically assisted mechanical, carry your key fob with blade key.
Dinozero
Dinozero
Kentucky
OK, the blade key makes sense if you were stuck on the outside. But if you were a toddler on the inside. Or an older kid. If they just pull on the hand will the door open? If the battery was dead
TheBigBezo
Earth
F-150 Lightning Lariat ER
I might be tripping but aren't there little mechanical levers that raise and lower when locked and you just grab those to unlock or am I remembering an older truck?
They're there but can't be manually controlled. Huh. Today I learned something new. I figured you could just pull on it.
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
Would need mighty small fingers. About toddler size if the toddler was aware enough to pull the lock button up.
But two pulls of the inside handle should work.
Mechanical. No battery needed.
Dinozero
Dinozero
Kentucky
The teslas have a mechanical unlock too. It’s front in front of the window controls. It’s a pull latch.
They’ve gotten better. The rear doors in my model 3 either didn’t have a latch or it was really in a hard spot to get to. I can’t remember but it was bad
I remember that latch tho.people would always accidentally grab that instead of press the button.
WilliamRobert
2022 F-150 Lightning, 2021 Mustang Mach E
happily retired!
The locking modes are selectable on the sync screen. I have mine set to only unlock the driver's door when entering and to lock with the walk away locking mode. Mine is a Lariat so those options may not be available on all models.
As others have noted, they are manual. If you were to take the door panel off you will find the cables and connecting mechanisms to the handle on the inside and the pop up lock. No motors involved.
The front doors if they are locked, pull on the handle and they unlock and open. The back doors you must pull the handle twice and they will unlock and open, UNLESS you have the child lock turned on.
davehu
hot springs, AR
I checked this out after I read the toddler story. The front door locks inside my 23 Lariat are too short and you cannot grab them (except with a pair of pliers) to unlock a door. However I did notice that for some reason the rear lock "stems" are longer and can easily grabbed to unlock the doors from inside. Why who knows but it's good to know that if in an emergency the rear locks can be opened from the inside without any power assist
Whitewater64
Scott
Palm Springs, CA
MY 23 F150 Lightning Lariat ER Max Tow Star White
Singer/Conductor
I have a '23 Lariat, but don't have a toggle to turn on Walkaway lock. It's in the manual, but I'm finding no option in settings. Did Ford put it in the 22's and then take it out for 23's? I LOVED that on my GM cars (and hubby' s Lyriq).
