F150 Lightning FORscan thread
kraxner
Colorado
2023 Ford F-150 Lightning Platinum
Is there a condensed list of options and the codes? Specifically for a 2024 Lariat ER if that matters? 56 pages is a lot to get through and it seems updates have occured on some mods throughout the 56 pages. F150 forum has a file for 14th gen f150'd with a common tab. Wondering if those work for our lightings as well. I have a friend who is going to code for me, he has a ranger raptor but he asked I bring the codes to him.
lol....I feel the same way, my friend.
At the same time, there are changes over time that are being reported that affects some of these changes. I wish there was an easy way to subscribe to the changes for just the mods we each make.
SNBI18
NJ
24 Lariat
I'm not even sure what options we have with the lighting because of how unorganized this thread is.
astrand1
Alex
Ford Fusion energi
Studio truck driver
If someone has the list of changes needed to add the “advanced security pack” could you post that. I got the little blue box that goes in the inside the upper console but I can’t find where I saw the changes in forscan needed. Thanks all!
21st Century Truck
Martin
Try this general F150 FORScan tricks Google document, by LivinItUp (obviously, not all apply to the Lightning but a lot do apply):
KennyB123
Ken
San Antonio, TX
Ford F150 Lightning
First try with forscan and glare free lighting is successfully "installed."
Haven't had a chance to test it out at night yet.
The majority of the changes that worked - Glare Free Lighting are all updated and listed in post 1.
Through out the thread there has been some information about getting Walk Away Lock to work for those that had the PAAK option and another part about getting side cameras to come on with the blinkers.
Both of those last two are connected to newer software that you must have and Ford has not formally updated our trucks with it. You may need FDRS to install that software to be able to play with either of those options.
SNBI18
NJ
24 Lariat
My Lariat has walk away lock already and the global windows with the key feature. These are all toggled options including some others on my screen.
techmatters
Pennsylvania, USA
'23 Lightning Lariat ER Antimatter Blue
Does your global window feature work on all windows (maybe even sunroof) or just the front 2 windows?
Anyone here feel like being a guinea pig to see if the Beosonic menu works on these trucks? It seems work on 21-23 Mach E's and 2024 F150's, but over on the ICE forums, we have not been able to get it to work on 21-23 trucks:
783-01-01 xx1x xx
7D0-01-01 xxx8 xxxx xx (The 2024 F150 had to use a 9 here instead of an 8, so try a 9 if the 8 does not work)
ChippewaBarr
23 Lightning Platinum Agate Black
Do you have a link to a post or thread discussing this? Would like to try it out - Ioniq 5 has this and it's such a great feature.
I did this yesterday. First you need the dealer to update your BCM module. This alone will turn on WAL. Then to enable on/off buttons in Sync, you either need the latest APIM update or you can go in FORScan and make this change in the APIM:
7D0-09-05 xxxx Cxxx xx-- (see note)
(or you can use Easy Mode on the APIM, and enable Walk Away Lock and Walk Away Lock Feedback)
You can make the APIM changes now and the sliders will show up under Locks in Settings - but they won't do anything until the BCM is updated.
Note: Changing the 5th byte of 7D0-09-05 to "8" enables the WAL on/off slider and changing to "C" enables both the WAL on/off slider and the Feedback on/off slider (horn honk). You will want both sliders.
783-01-01 xx1x xx
Tried it and it works! I used instructions from Mach-E forum:
Code:
783-01-01 xxXx xx - Add 1 to X  (this is DSP As Built)
7D0-01-01 xxxX xxxx xx - Add 8 to X  (this is APIM As Built)
On my truck for 783-01-01, it was a 0 so I made it 1.
For 7D0-01-01, it was an 1, so I made it a 9.
So just like you said for the 2024 ICE. I'm not an audiophile so didn't test it. For just radio, I couldn't tell a difference.
@vandy1981 : can you add this to your first post?
Ford F-150 Lightning F150 Lightning FORscan thread 1727382185698-00
