ChrisCon
- First Name
- Chris
- Jan 7, 2022
- The Hamptons, NY
- '22 Carbonized Grey Lightning Lariat ER
So I'm looking at your updates ...Help
On October 1, I see no issues at the end except you did the ACM and RFA updates many of us have done. They don't actually update on your truck as it only takes 2 minutes per udate and then afterwards you run Programmable Module Installation. Just curious, but why did you run this? That isn't needed for software updates. You then run 360 Degree Camera Alignment which is another thing not needed for software updates. You then run the 360 Degree Camera Alignment thing another two times on October 2nd.. It looks like most of your problems are repeated running of these alignments.
Then today you didn't actually update anything but ran the PMI program multiple times and the IPMA programs (like configuration and data collector) but not the update ones.
Then Rugedraw looked at your truck through PTS
and after he did you are just running alignment programs again.
Here's the part I don't know about, but may be your issue- I know some camera alignments require either A. driving or B. using special symbols and colors placed around the truck. I think you may have gotten yourself into an issue by not following those steps and then just repeatedly running alignment programs.
Can someone else more knowledgable then me, confirm or refute that you need special tools to do the alignments?
It looks like you could have just cleared your DTC's in FDRS and your truck would have been fine with what you were doing up to October 1. My steps whenever my truck runs out of juice during an update (doesn't really happen anymore since I've spent money on tenders), are to just click retry after charging the LVB to 100% and then just clearing all the DTCs in FDRS when done.
As far as I can tell all of your updates have gone through successfully and all errors are because of the alignment programs you keep running.
The only updates you should run again are the RFA and ACM updates as the completed to quickly.. They won't clear when done, but the RFA should take 30 minutes to complete. That's how you know it worked.
