user-name-required
Touché. Point is still valid I don't want panels touching and rubbing against each other.Aluminum doesn't rust.
They charged it to near full for me, I think it was at 99% when i got it.What was the SOC when you picked it up at the dealer? How many KMs on the truck? It can be the battery pack may be a bit out of sync from sitting and inconsistent charging, or from a number of things already mentioned.
If the pack is a bit out of sync from sitting or just because it is new, it should settle under normal, regular use.
Comes with all 2024 Lightnings, when we will see it as an OTA, no one knows......Ok, is no one asking about this little item? Which update added this? Have a 2022 and have been missing having this useful piece of info when charging.
I know I'm kind of late to this conversation. And I 100% love driving my lightning, and highly recommend it as a city truck. But if this is a worry I don't think the lightning is the truck for you. Consider a powerboost instead. Or wait for the powerboost to be a PHEV, or look into the Ram Charger in the next couple years when it launches. Especially when it gets cold in BC, even with the heat pump on the 24, you're going to suffer a range hit on the temperatures. It's not a safe bet that the F150L is going to get you through when towing.Very, very seldom would we need to DCFC to 90 or 95, but I still wanted to see what it looked like as there's still some stretches here where I live in BC (entire province is mountainous) where you're ~250 kms between chargers that can do over 50kw....so for when we are towing, it becomes more of an issue.
They did say they were already towing with their other EV, so I think they know what to watch out for. I agree if towing long distances is the *primary* use case then maybe the Lightning isn't the best choice, but if it's occasional, and mostly in good weather like typical camping uses, it'd be OK.I know I'm kind of late to this conversation. And I 100% love driving my lightning, and highly recommend it as a city truck. But if this is a worry I don't think the lightning is the truck for you. Consider a powerboost instead. Or wait for the powerboost to be a PHEV, or look into the Ram Charger in the next couple years when it launches. Especially when it gets cold in BC, even with the heat pump on the 24, you're going to suffer a range hit on the temperatures. It's not a safe bet that the F150L is going to get you through when towing.
As noted, yes we tow already with our ID4. Our trailer is a tent trailer and with the ID4, it has a vertical bike rack off the back of it....aka a giant air brake. We can get about 180-200kms between chargers with that thing, while "clean" on the highway on a trip like this, we could get about 350 if we really pushed it. 250 if we had the vertical rack on the car instead.....crazy how much aerodynamics impacts efficiency!!They did say they were already towing with their other EV, so I think they know what to watch out for. I agree if towing long distances is the *primary* use case then maybe the Lightning isn't the best choice, but if it's occasional, and mostly in good weather like typical camping uses, it'd be OK.
As for the original question. I have not seen charging rates jump around like that. My 23 XLT ER drops suddenly to 55 kW or so at 80%, then flat up to 89% or so, then tapers off again after that. I'd be interested to see what the truck and charger are telling each other while it's behaving erratically. Car Scanner might offer some insight. Maybe some strange interaction with that particular charger.
Vancouver IslandMay I ask where in BC you are?
