Danface
Dan
Central Mass
2023 Lightning XLT
One thing I've noticed when the battery is cold that it warms up quickly if I accelerate, coast and repeat for about 15 minutes (little hills in the road help too). It makes sense to me that this "surging" would do that but I wonder if it messes up the battery. I'd suppose that's unlikely seeing how "that's how it was built" so to speak.
I call that "Grandma Mode". My Grandmother would step on the gas, then come totally off, then step on the gas, then come totally off. Great case of whiplash when you went for a ride with her.
Maxx
My guess is, it does mess up the battery. Even without winter condition considerations some manufacturers limit number of hard acceleration to protect the battery. When you accelerate hard, sometimes you will have to decelerate hard too which heats up your batter more but hi current charging (regen) a cold battery causes Lithium plating which over time can result in thermal runaway. How much time it takes for the stuff to hit the fan is a function of your pack and your luck. I try not to push my luck too much.
Danface
Dan
Central Mass
2023 Lightning XLT
I don't accelrsted quickly, more like "pulsing" rather than "flat" acceleration when driving and even going a little quicker up small hills and coasting down.
Maxx
This is power going in and out of my battey in 1.5 hr drive on a warmer day. I don’t believe Ford limits any of these in cold days. You can see regen is like DCFC hitting 100 KW. and in one occasion acceleration pulled 260 KW. I don’t remember how much flooring it pulls. Just wanted to give you some numbers for reference.
Ford F-150 Lightning Ford's Important Tip For Driving Your Lightning in the Cold: Preconditioning / Pre-Heat Your Battery Screenshot_20241223_123538
WoodduckMN
Andover, MN
23 Tesla Y, 22 Lightning Lariat, 21 Chevy Bolt, 13 Ford Explorer
Manager
Wish @Ford Motor Company would allow us to set charging to be completed for a set departure time like Tesla and Chevy do. Then the battery would be warm at the time of departure. Rather than setting a charging start time, set the daily departure time and let the computer in the truck determine when it needs to start charging to be ready for the departure time. Works great on my Bolt and Tesla.
Danface
Dan
Central Mass
2023 Lightning XLT
Thanks! It would be interesting to log the change of battery temperature as it relates to different driving "styles". I now have my charger hooked up so I let that maintain the battery in the winter.
Danface
Dan
Central Mass
2023 Lightning XLT
Add to that a "Condition the battery now" button and I would use the Ford app! It would be like "hmmm, we're leaving in 15 minutes so maybe ready the truck?"
