B177y
- First Name
- Bill
- Jul 16, 2024
- Olympic Peninsula WA
- Website
- www.ptcoffee.com
- 2024 Lightning Pro ER Max Tow
- Occupation
- Coffee Roasting
I am wondering if anyone can help me with this mod.Fix front camera not popping up on screen when front sensor activated (source)
IPMA: 706-16-01 xxx*-xxxx-xxxx
if old value 0-7 then add 8 (hex) to get new value. For example 3=>B. If current value is 8-F, then this is not for you. Applicable to trucks without Park Assist and BC.
If I remember correctly, I had to change this IPMA value to "radar camera fusion 110-degree" or something like that to activate my LKA/ACC addition to my 2024 Lightning Pro (ER, max tow, tow tech, 360 camera... NO park assist and no front parking sensors). This matches the recommended IPMA setting above, but adjusted for my truck's factory AB.
I don't have a toggle to enable the front parking assist. I looked through @Livnitup spreadsheet to try and find a setting in the IPC to enable a toggle, but I haven't been able to find anything that seems to fit the bill. The ICE post linked above doesn't have any info on adding the toggle either.
The source and the setting above imply that I should be able to have the camera pop up without having the small bumper sensors and only using my front camera and (new) CCM radar. The original mod seems to show that the trucks have a front park assist toggle already in the settings menu and the ForScan mod just enabled the camera and radar where I have the opposite, my camera and radar seems to be on the right setting now, but I don't have a toggle to enable it.
Any suggestions on where to look in ForScan and what the description would be on the spreadsheet to enable the front camera park assist toggle? Also, if this is something that can't be enabled on my truck, let me know and I'll save everyone's time. Thank you!
