B177y
Olympic Peninsula WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
Fix front camera not popping up on screen when front sensor activated (source)
IPMA: 706-16-01 xxx*-xxxx-xxxx
if old value 0-7 then add 8 (hex) to get new value. For example 3=>B. If current value is 8-F, then this is not for you. Applicable to trucks without Park Assist and BC.
I am wondering if anyone can help me with this mod.
If I remember correctly, I had to change this IPMA value to "radar camera fusion 110-degree" or something like that to activate my LKA/ACC addition to my 2024 Lightning Pro (ER, max tow, tow tech, 360 camera... NO park assist and no front parking sensors). This matches the recommended IPMA setting above, but adjusted for my truck's factory AB.
I don't have a toggle to enable the front parking assist. I looked through @Livnitup spreadsheet to try and find a setting in the IPC to enable a toggle, but I haven't been able to find anything that seems to fit the bill. The ICE post linked above doesn't have any info on adding the toggle either.
The source and the setting above imply that I should be able to have the camera pop up without having the small bumper sensors and only using my front camera and (new) CCM radar. The original mod seems to show that the trucks have a front park assist toggle already in the settings menu and the ForScan mod just enabled the camera and radar where I have the opposite, my camera and radar seems to be on the right setting now, but I don't have a toggle to enable it.
Any suggestions on where to look in ForScan and what the description would be on the spreadsheet to enable the front camera park assist toggle? Also, if this is something that can't be enabled on my truck, let me know and I'll save everyone's time. Thank you!
what do you mean by reset APIM? I dont recall having to do that when I enabled my Glare Free lighting?
When it tells you to turn off the power to the truck it's being reset.
I need to put more instruction on this one I guess. To reset any module, see the second half of post 129, also linked by @BlakeGJ a couple of posts back.
Are you suggesting you need to do a reset after the power cycle? Forgive me for posting bad information if that's correct.
No worries. It seems certain mods are more successful if modules are reset. FORScan has a way to reset a module using the wrench icon menu. I doubt power cycling is the same - in some instances when folks have had SYNC issues, power-cycling didn't work but the steering wheel reset would.
Livnitup's tutorial does indicates a FORScan APIM module reboot and the steering wheel trick are equivalent. But for other modules, there is only FORScan.
I just want to keep the process pure to the original developer. If they say reset a module, they mean use the FORScan wrench menu. It takes less than a minute after you do the write command.
I will add additional instructions to those mods on how to reset.
evowner
Frank
SW Ohio
Retired EE
Enable B&O Beosonic Equalizer (B&O Sound systems only) See this post for info and screenshots. Reported not working on 2024 Flash (post). Please reply to that post if it works for a 24+.
APIM 7D0-01-01 xxx* xxxx xx-- Add 8 to * (mine was "1" so made a "9")
DSP 783-01-01 xx*x xx-- Add 1 to * (mine was "0" so made a "1")
I wonder first of all why this is not enabled by default on a vehicle that has this system? second has anyone done this and does it work? I am especially interested in the equalizer.
21st Century Truck
Martin
Member XENOILPHOBE and I have turned it on in his truck. The sound really is appreciably better. He was still trying to get the visual screen "color wheel" control to work the last time we had touched base. He's got the Platinum with 18 or so speakers.
evowner
Frank
SW Ohio
Retired EE
I appreciate that. I guess I will try to enable it and see if it does anything for me. I think I only have 8 speakers though, but it does have that brand marked on the speakers. Even with the tone only adjustment it does sound pretty good. I would like to tweak that in a little more so just the equalizer working would be OK with me.
Curious what you discover. I think at least a couple of folks with a 2024 Flash could not get the Beosonic tab to work.
moodinsk
Tyler
2024 F150 Lightning Flash
I have a 2024 Flash that I got in Dec 2024 as indicated in my post. I gave up trying to get the beosonic menu to work in my truck.
I have yet to receive any OTA updates, but my current SYNC4 version is 24145 rev 1286. Beyond that, I am not sure how to tell what other potential version changes in the software that might cause it to not work vs the 2022-2023. I know there was at least one other person that posted with the same issue I have that had a 2024.
evowner
Frank
SW Ohio
Retired EE
I am new to forscan and I do not have any experience with the CAN buss for communications and register modifications. I just got my cable, and I will try to get up and running with this stuff. I am wondering if something else has to be enabled? Maybe it is not only a software enable, but something in the amplifier too? Although from what I have read it does seem like the software is the problem. I also need to download as many wiring diagrams as possible with a 3 day pass. I hope I can teach my 70 yr old brain new tricks.
brtnstrns
Seattle
2024 Lightning Platinum; 2022 Polestar 2 LRDM
I have a 2024 Platinum and the Beosonic change did not work for me either.
scruvs
This was one of my biggest frustrations with the majority of FORSCAN tutorials and videos out there, inclyding livinigitup's own tutorials. When you just get stated most changes, instructions, and videos just say to change value X to value Y.
In truth EVERY change should be evaluated and you need to take your original value, compare against the spreadsheet, and determine exactly what the resulting value should be. This is not expressed enough, especially to new users. The number of members who have not read the spreadsheets is concerning.
In many cases the numbers you see online will be different if you have an XL, XLT, or Lariat trim with an ICE engine, and then again completely different for Pro, vs XLT, vs Flash, vs Lariat in the lightning.
I appreciate your comment on this frustration. I was aware of the spreadsheets, but didn't really know how to read them. I was blindly following this thread's instructions to change a to b, or if you have w change to x, else y to z. I realize it was safer following these vetted Lightning changes vs. using ICE settings, but it is so much more comforting to see the setting I had before and what feature was enabled after the change.
Scorpio3d
SS/IBA car wash owner
I actually tested it out today. With the 50/50 mod I get the following views when not moving:
Once moving the two forward facing views and the 360 disappear (the first three in column 1). The top right icon is the optional add-on trailer cam which I don't have. So when moving I have bed, tailgate, 50/50, and hitch icons - and the first three work at speed (I didn't test hitch - kinda useless when going 40 mph).
So maybe when you enabled 50/50 or removed the Full View not available message, something got mixed up. The values in post 1 are Lightning specific. If you used values from the original thread or somewhere else, you may have killed bed camera at speed.
There is a setting for cameras at speed in the ICE F-150 spreadsheet I need to investigate it more. I'm pretty sure I didn't do any mod to get cameras at speed but I could be wrong about that.
First off, I have not done any of the updates except for glare free and BC 1.x and I was trying to use my cameras the other day and my bed camera (all cameras )did not work except when I was stopped??
I thought maybe it was one of the other updates from FDRS/OTA??
CRAIGC540
Craig
Moreno valley
Technician
I just noticed after looking at a old photo of my screen that the 360 cam view is smaller, I'm not taking about small like after the front sensor update because that was even smaller. I'm wondering if it's smaller after the 50/50 view forscan change. Notice the menu button to select which camera view you want. Now the camera view is always in view.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1000005072
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1000005069
